24
OxygenOS 10.0.14 and 10.3.8 [India] for the OnePlus 7T Pro
  1. Abhishek029 , via OnePlus 7T Glacier Blue , Feb 2, 2021 :
    Always on 90Hz, Auto Brightness is On always, Black theme, Black wallpaper
    Also I don't play any heavy game or not using any heavy app.
    Normal usage And getting SOT around 7-8 hrs every time now.
    #81
  2. Louisbaecke510
    Honeycomb Feb 2, 2021
    Louisbaecke510 , via OnePlus 7T Pro , Feb 2, 2021 :
    have had the same problem, I have this hardened reset problem was gone
    #82
  3. #83
  4. Louisbaecke510
    #84
    Abhishek029 likes this.
  5. #85
  6. Abhi.0.0.7 , via OnePlus 7T Glacier Blue , Feb 2, 2021 :
    Every body says that's OnePlus is best while releasing there updates time to time I thought it's real then I bought 7t and f**k it they are also like other company while in realising there update too late still I am running September security patch update ..
    #86
  7. AlbertoK
    Gingerbread Feb 2, 2021
    #87
  8. ghostofcain
    Marshmallow Feb 2, 2021
    ghostofcain , Feb 2, 2021 :
    I don't, but then again a VPN won't help as the roll out is not geographical.
    #88
    AlbertoK likes this.
  9. J1577769579265
    Froyo Feb 3, 2021
    #89
  10. firdaus57
    Eclair Feb 3, 2021
    #90
    amitverma38 likes this.
  11. raju.swaraj
    Cupcake Feb 3, 2021
    #91
  12. Caomhin
    OnePlus 9 Series Expert Community Expert Feb 3, 2021
    Caomhin , via OnePlus 6T , Feb 3, 2021 :
    Remove all Screen Locks, Pin, Fingerprint and Facelocks etc
    Restart the phone.
    Setup your Fingerprint once more.
    Check if that helps.
    #92
  13. Caomhin
    #93
    ghostofcain likes this.
  14. Attached Files:
    #94
    sravan donugari likes this.
  15. firdaus57
    Eclair Feb 3, 2021
    firdaus57 , via OnePlus 7T Pro , Feb 3, 2021 :
    Tried these methods but still same issue. 😑
    #95
  16. Caomhin
    You can use one or more options below to send Bug reports on the issues back to the OnePlus OOS developers.
    Feedback tool
    You can also contact bughunters@oneplus.com
    And also contact OnePlus support directly to see if they have more information on your issue. Scroll down the page for contact and online chat details.
    #96
  17. G_Håkan_Fors_RViU
    Cupcake Feb 3, 2021
    #97
  18. Caomhin
    Works fine on my 6T.
    Make sure you are on the most recent version of GPay.
    Clear the GPay App info Cache and App info Storage as well.
    See if that helps.
    #98
  19. G_Håkan_Fors_RViU
    Cupcake Feb 3, 2021
    G_Håkan_Fors_RViU , Feb 3, 2021 :
    Thanks, gonna try. Cleared app info and storage, uninstalled gpay from the play store and installed the updates again. Also rebooted the phone. New try tomorrow see if it cleared things up.
    #99
    accuphase and Caoimhín like this.
  20. Vaibhav_Lacman
    Gingerbread Feb 3, 2021
