354
OxygenOS 10.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. Paulo Viana
    Gingerbread Nov 24, 2019
    Paulo Viana , Nov 24, 2019 :
    [QUOTE = "G_Yaswanth_V_Adhikari_fv, post: 21072252, membro: 991584"] está cheio de bugs whatsapp não está funcionando bem, existe uma barra branca embaixo do teclado em geral, existe um desconforto ao usar o telefone. a suavidade do telefone se foi. por favor não atualize. sou um atualizador regular, então eu sei como limpar o cache e tudo isso, por favor, não atualize. oneplus corrija-o. estou meio cansado de usar o meu 7 pro. o consumo de bateria é insuportável. estou à beira de vender meu telefone. software não é mais uma iguaria. #hatethenewoneplus [/ QUOTE]
    Lol
  2. Rodolfo28
    Cupcake Nov 24, 2019
    Rodolfo28 , Nov 24, 2019 :
    Wipe caché and data, install 10.0.2 and all will be perfect.
    Working 100% for me...no bugs
    Netsky60 likes this.
  3. KevinSidpara
    Gingerbread Nov 25, 2019
  4. Last edited by a moderator: Nov 25, 2019
  5. jame_li likes this.
  6. Rajesh vaghasia
    Cupcake Nov 25, 2019
    jame_li likes this.
  7. J1561393176909
    Froyo Nov 25, 2019
    jame_li likes this.
  8. Kamilo316
    Eclair Nov 25, 2019
  9. ldwp27 , via OnePlus 7 Pro T-Mobile , Nov 25, 2019 :
    how do I do that?
  10. CharanGarapati
    Froyo Nov 25, 2019
    CharanGarapati , via OnePlus 7 , Nov 25, 2019 :
    Issues:-
    1.Ram Management is very worst.
    2.Battery Draining.
    3.Wallpaper Set Issue on Launcher.
    4.Navigation Gestures (Left or Right) mode is difficult to use in landscape mode.
    5.Using Of Third party Icon packs sometimes icons are getting into White Icons.
    6.Proximity sensor issue during call sometimes.
    I found these issues only on OnePlus 7.
    Features needed for Oneplus7:-
    1.Super Stability Mode.
    2.Macro mode.
    3.Better Battery life.
    4.Need Improvements in Nightspace mode.
    5.Add face unlock to App locker
    6.Custom Gestures for User can create to use
  11. picopop
  12. dsiz_prince
    Froyo Nov 25, 2019
  13. abqnm666
    Eclair Nov 25, 2019
    abqnm666 , via OnePlus 7 Pro , Nov 25, 2019 :
    Ugh. 10.0.2 is awful for the Pro. Android system uses hours upon hours of background CPU now, even with a clean wipe. Before I was lucky if it had 20 min of Android System cpu usage per day and deadly consistent 7.5h SoT over 24h. Now it's 3-5 hours of SoT max, with 12-18 hours standby, with the rest being consumed by Android System.
    And no Whatsapp or other known issue apps. Android System is abusing the CPU and it's awful.
    Also having the system theme "tone" reset to white every time I use Android Auto is really getting annoying.
  14. Amits7251
    Froyo Nov 25, 2019
    Amits7251 , via OnePlus 7 , Nov 25, 2019 :
    what the hell are you doing with updates ,, first of all very slow updates ,then buggy , fingerprint is still.slow , and charging sucks , it takes more than 90 minutes to charge full ,still didn't removed bugs and just giving buggy updates every time and for that buggy update we have to wait , seriously just verify and check all issues with the updates then provide it ,just to maintain you reputation of fast update provider , you provide buggy update every month , seriously change this shit else downfall of one plus is on the way ,
    P1567915556992 likes this.
  15. AR8ITRAT0R
  16. Kruzer
    Kruzer , via OnePlus 7 , Nov 25, 2019 :
    i also have a OnePlus 7 but my phone goes from 10-90 in just 55 min not once every time so either your device is faulty or other issues can be there with your device
  17. Swejuggalo
    OnePlus 9 Series Expert Community Expert Nov 25, 2019
    Swejuggalo , via OnePlus 7 Pro Mirror Gray , Nov 25, 2019 :
    Do you charge over night sometimes?
    I have never had that bad battery on any of the betas since beta 1. On beta 6 now. I'm not a gamer though. Reading and writing mostly. Near 10h at best.
    Bernest44 likes this.
  18. Swejuggalo
  19. J1574658552069
    J1574658552069 , Nov 25, 2019 :
    I'm having issues sending any pictures from my gallery. if I take a picture when in the messaging app it will go through, but if I try to forward the picture already taken it does not go through. Has anyone had this issue .(Oneplus 7T)
  20. UnicornZ
    Ice Cream Sandwich Nov 25, 2019
    UnicornZ , via OnePlus 7 Pro , Nov 25, 2019 :
    Pls read again. He said full charge. That means 100%. Not 80. For u, to charge 80% of 3700mah it takes 55 min which is still awful in terms of "dash" charge.
