354
OxygenOS 10.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. B k
    Ice Cream Sandwich Nov 29, 2019
    B k , via OnePlus 7 Pro , Nov 29, 2019 :
    battery has improved in 10.0.2, but then depends on ur usage, which apps u install,etc..
    heating issues still persists for few many users, while playing games.
    Petko_Antonov likes this.
  2. Petko_Antonov , via OnePlus 7 Mirror Gray , Nov 29, 2019 :
    well if you play heavy gfx games it's normal for the device to heat up. once I've played asphalt 9 for over an hour and the device heated up.
    B k likes this.
  3. Josep1010
    Eclair Nov 29, 2019
    Josep1010 , via OnePlus 7 , Nov 29, 2019 :
    The battery charging has slowed down alot after the latest update.
    30 mins - 42%
    60 mins - 82%
    1 hour 35 mins - 100%
    Had the Dash charger gone Dhuseee.
    coolakki and mahekparmar like this.
  4. Q1561224713398
    Eclair Nov 29, 2019
    Q1561224713398 , Nov 29, 2019 :
    First of all don't talk to me like I'm a child. I don't cry my little eyes out or whatever else petty things you can come up with.
    I just did the factory reset.
    Guess what.. All my settings gone. All personalized setups for the system, all sms messages, all sounds, visual settings, dark mode, basically everything that is not any app specific.
    Did I backed up the data before reset? YES. Full Google backup including system settings, sms messages and all that it allows to.
    If I was pissed off before by the bugs this phone has, then don't ask how I feel right now.
    Essentially I have already spent few hours to make sure everything is backed up, then wait for the whole reset process, and now.. I need to go over each of my settings and apps manually to get them where they were before.
    Did the reset fix the previously mentioned issues?
    Early to confirm. Lock screen background image is still different from the main background image which I had to change.
    At this point I am close to throwing this piece of phone against the wall.
    Removed by mod
    The frustration this device has already brought me over the past 4 months and the "customer service" this company has... No comments.
    B k, B1566878277223 and Anishrajus like this.
  5. Anishrajus
    Honeycomb Nov 29, 2019
    Anishrajus , via OnePlus 7 Pro , Nov 29, 2019 :
    exactly bro! well said!
    fanboys (op sheep's) mantra: factory reset and clear cache and they never admit that it as a bug!
  6. Fadi.t
    Donut Nov 29, 2019
    Fadi.t , Nov 29, 2019 :
    on top of the great Hardwear OnePlus builds; it's the constant support, updates and enhancements OnePlus is committed to keep providing to its users that makes OnePlus devices the best!
    I still haven't received OTA update yet and can't wait to receive it.
    any idea when it's gonna rollout to all users without any limitations?
  7. ParasJain7
    Eclair Nov 29, 2019
  8. gaursayyam
    Froyo Nov 29, 2019
    gaursayyam , Nov 29, 2019 :
    Hey. that was surprisingly good! Keep updating the Easter eggs
    B k likes this.
  9. X1569063032038
    Froyo Nov 29, 2019
    X1569063032038 , Nov 29, 2019 :
    may be within few days now..i just received it yesterday..i didn't get update notification but it was there when i refreshed the '' Check for updates''
  10. Fadi.t
    Donut Nov 29, 2019
    Fadi.t , via OnePlus 7 Pro , Nov 29, 2019 :
    thanks bro I appreciate your response.. I'm refreshing the update everyday.. will wait!
  11. Arnaud_Ieè
    Eclair Nov 29, 2019
    Arnaud_Ieè , Nov 29, 2019 :
    Android auto is up to date unfortunately.
  12. mannunikhil
    Eclair Nov 29, 2019
    mannunikhil , via OnePlus 7 , Nov 29, 2019 :
    Call waiting gets connected after 5-10 secs automatically by disconnecting the active call.
    This is so weird, does anyone else has seen such behavior?
    Its there since ver. 10 was installed.
    Please suggest.
  13. MSA_1972
    Cupcake Nov 29, 2019
  14. biswasritik
    Donut Nov 29, 2019
  15. F1562182140755
    Donut Nov 29, 2019
    F1562182140755 , via OnePlus 7 , Nov 29, 2019 :
    it's feeling fine, great improvements. You should download it in my opinion. Battery drain also depends on apps you use. I charge to 80% at morning and have about 15-20% before night
    B k likes this.
  16. A1574346103209
  17. C1557198791856
    Donut Nov 29, 2019
  18. rakeshhajare
