354
OxygenOS 10.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. Swejuggalo
    OnePlus 9 Series Expert Community Expert Dec 1, 2019
  2. Rajat jain16
    Donut Dec 1, 2019
    Rajat jain16 , Dec 1, 2019 :
    I think that OnePlus is not focusing on this phone i.e OnePlus 7 . there are many problems that we are facing.
    i request to OnePlus team to please focus on this model of OnePlus and make it better.
    We are feeling that we have wasted our money on it.
    only 6 months have passed but we feel that our phone is so degraded.
    SandeshChinchapur likes this.
  3. Swejuggalo
    Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 1, 2019 :
    So very wide spread results depending on user. Some have great experiances and some bad. Many factors matter and it's near impossible to say that doing this and that fixes everything or not. All I can say is that alot of things improve after a factory reset after upgrading from 9 to 10. I would recommend to register as a new device though so you don't recover app data during the setup process. Better to use a Oneplus Switch backup since it does not save appdata.
    Android 10 has a few issues here and there. And it's not limited to Oneplus. Even Pixel devices has issues. So some issues come strait from Google. Apps with poor 10 compabilty sure does not help either.
    Rolling back to 9 can be a temporary solution... However you missout on security updates and when you try a new 10 update you might go back to a problematic 9/10 upgrade situation again. So I would recommend a clean factory reset and use that for a few days and spend some time analyzing the apps behavior. Some developers simply need to speed things up so their apps work nicely on 10. You might be able to solve some issues by using beta versions of some apps until they work properly on 10.
    Update/Downgrade your phone with starting from the community app. Step by step video. Some awesome entertainment during the download included. Downgrade file exists in the first post in OB1. (Downgrades to AA, International. Manually upgrade to whatever version you want)
    https://forums.oneplus.com/threads/...-for-the-oneplus-7-and-oneplus-7-pro.1099154/. Video http://bit.ly/2lPAkuy
    Rajat jain16 and Saurabh10192 like this.
  4. chau10
    Donut Dec 1, 2019
    chau10 , Dec 1, 2019 :
    After updating to 10.0.1, battery is draining while mobile in not in use.This problem is not in 9.5. Clear this bug
    I still havent received 10.0.2
  5. G_harsh_kadian_
    Cupcake Dec 1, 2019
  6. Swejuggalo
    Either wait or install it yourself via local upgrade. You can find full update files in this Telegram channel for example.
    OnePlus[e]2122[/e]
    Everything OnePlus #NeverSettle
    Not endorsed by OnePlus
    https://t.me/OnePlus
    (open up with Telegram app)
  7. Last edited: Dec 1, 2019
  8. G_harsh_kadian_
    Cupcake Dec 1, 2019
    G_harsh_kadian_ , via OnePlus 7 Pro , Dec 1, 2019 :
    Thanks mate
  9. G1565848762455
    Cupcake Dec 1, 2019
    G1565848762455 , via OnePlus 7 Pro , Dec 1, 2019 :
    Hello Experts, My devise is Op7 pro. and my operating system is Op7pro_2 beta_6. Well, if I use open beta, can I not use upgrade 10.0.2 ?
    And I want to know What is the way to return to the official buld from Open Beta?
    thanks on advance.
  10. S1570480943004
    Donut Dec 1, 2019
  11. Rockingbks
    Gingerbread Dec 1, 2019
    Rockingbks , Dec 1, 2019 :
    I agreed with you but battery draining while active usage is abnormal. its be Flipkart amazon or even OnePlus community app or Twitter Facebook YouTube everywhere battery consumption is heavy.
    Its 7nm processor based chip dear and 4000 mah battery.
    you know kirin 980 or even Apple bionic chipset
    They are known for less battery consumption.
    OnePlus is bringing bad for even Qualcomm.
    we want 9.5.11 efficiency
  12. P1570169964875
    Donut Dec 1, 2019
    P1570169964875 , Dec 1, 2019 :
    facing gyro problems in playing pubg.the aim moves on its own without moving my phone...facing this problem since 28 November and also the recent update came of 166mb .i did update my phone but it still the same ..please fix this gyro issue while playing games.i m using android 10
    i called to customer care and also mailed them .they said *#808# will work but it doesn't ...they told me to factory reset my phone.i did that too but the problem remains the same..gyro moving on it own towards charging point direction....while i also see this same problem in OnePlus 7 pro.the aim is moving towards up direction...
  13. Dhiravindh786
  14. Swejuggalo
    The first moments after an upgrade is often not that great. It needs some time. Leave the phone on the charger a night and the performance should improve.
    In worst case you have some app that causes lag. So check your battery stats for strange behavior.
    Sometimes the underlying cause of lag and drain may not be that easy to find. Especially if it is a 9 to 10 upgrade you just did. Then you might benefit from a factory reset and register as a new device during setup and recover apps and stuff via a backup (if you need a backup) made by OnePlus Switch. Usually worth it in the long run.
    After a factory reset there is some time that the OS tries to learn your usage pattern and will do some adjustments accordingly. So the optimal battery may need a few days. Depending on your usage you might get improvements with Ram boost On or Off. I run it Off since I don't feel like I need any of the benefits On gives me.
    I also use BetterBatteryStats to give a deeper level of battery info to analyze.
    zmuhammx likes this.
  15. S1570480943004
    Donut Dec 1, 2019
    Dhiravindh786 likes this.
  16. P1570169964875
    Donut Dec 1, 2019
    S1570480943004 and Dhiravindh786 like this.
  17. S1570480943004
    Donut Dec 1, 2019
  18. P1570169964875
    Donut Dec 1, 2019
