353
OxygenOS 10.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. SHIVAM97MANGLA
    Donut Dec 2, 2019
    SHIVAM97MANGLA , via OnePlus 7 , Dec 2, 2019 :
    Don't upgrade as quality is degraded even after 10.0.2.
  2. O1575273603871
    Cupcake Dec 2, 2019
    O1575273603871 , Dec 2, 2019 :
    facing the heating issue as well while charging..Should we wait for next update to come?
  3. Y1561702071664
    Cupcake Dec 2, 2019
  4. SHIVAM97MANGLA
    Donut Dec 2, 2019
    Yes I am also thinking of rollback but then again I have to do reset after upgrading to 10.
    Vijay10Kumaru likes this.
  5. Syed Ubed Quadri , via OnePlus 7 Pro , Dec 2, 2019 :
    what's app call and imo call are still not vibrating when mobile is on vibration and also in ringing mode even after 10.0.2 update.
    please fix this issue as early as possible.
  6. MRpirloking
    Eclair Dec 2, 2019
  7. G_Deepak_Shukla_ObEY
    Cupcake Dec 2, 2019
  8. F_Rahul_Jain_dMWi , via OnePlus 7 Pro , Dec 2, 2019 :
    same thing is happening to me!!
  9. Jatin020
    Gingerbread Dec 2, 2019
    Jatin020 , via OnePlus 7 Pro Nebula Blue , Dec 2, 2019 :
    It's because ... if it exceeds 5 minutes you will face low storage remaining issue .. as 4k 60fps videos are of big size extending there limits will create storage issues for users..
    F1566111390193 likes this.
  10. MRpirloking
    Eclair Dec 2, 2019
  11. himanshusaxena0001
  12. O1574659569333
    Cupcake Dec 2, 2019
  13. Q1570332614464
    Cupcake Dec 2, 2019
    Q1570332614464 , via OnePlus 7 Pro , Dec 2, 2019 :
    one plsus 7 pro :- camera app not working shows only black screen all the time.
    i am not able to login into the phone via face unlock, popup camera gets stuck open and there is only way to close it to lock my phone again.
    worst update i have ever seen in my life , core functionally is broken.
    how you guys can rollout such a broken update to mass users.
    please tell me how to uninstall this update
  14. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 2, 2019 :
    If something can happen it will eventually happen.
    Since these issues does not happen to everyone you probably should factory reset first before doing a rollback. A rollback will wipe the phone anyway so...
    During the factory reset register as a new device to avoid backed up app data from Google. Use a backup made with Oneplus Switch instead.
    It might be as simple as to wipe data of camera app and stuff too. Isolated incidents happen everywhere and will probably always happen.
    If a factory reset does not solve it I don't know what has happened. No other camera app works either? If camera always fails for you and works for most other users... Maybe try a full update file of 10.0.2 and reflash it. Can be found in various places. Like this Telegram channel.
    OnePlus[e]2122[/e]
    Everything OnePlus #NeverSettle
    Not endorsed by OnePlus
    https://t.me/OnePlus
    (open up with Telegram app)
    Anyway...
    Update/Downgrade your phone with starting from the community app. Step by step video. Some awesome entertainment during the download included. Downgrade file exists in the first post in OB1.
    https://forums.oneplus.com/threads/...-for-the-oneplus-7-and-oneplus-7-pro.1099154/. Video http://bit.ly/2lPAkuy
    Before doing anything you can also report this issue with the feedback tool.
  15. akks
    Jelly Bean Dec 2, 2019
    akks , Dec 2, 2019 :
    Try clearing storage of camera, if not getting corrected, clear system cache, if still persisting, do hard reset. Never had such an issue in my 7 pro, running 10.0.2.
  16. akks
    Did you "train" it, manually? That's how adaptive brightness is supposed to work. If still persisting, clear data of device health services, either reset adaptive brightness or clear all data. Then train from the beginning.
    For me, adaptive brightness is way better than previous auto brightness.
  17. akks
    No, it won't come to 7 series, as of now, due to hardware restrictions.
    Confirmed be Oneplus staff, here:
  18. Rohit.singh@1995
    Cupcake Dec 2, 2019
    Rohit.singh@1995 , Dec 2, 2019 :
    I liked the manual notch display setting in the previous version, I think it should be totally on the user whether to keep notch on or off. Eventually it can help in battery saving as well.
    #NotchSetting #Manual
  19. Rohit.singh@1995
    Cupcake Dec 2, 2019
