353
OxygenOS 10.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. rohit928
    Donut Dec 2, 2019
  2. Sandy9678
    Ice Cream Sandwich Dec 2, 2019
  3. R1570721549354
    Donut Dec 2, 2019
    R1570721549354 , Dec 2, 2019 :
    Fingerprint animation issue is still there in my phone
    I updated my phone through system updates to oxygen os 10.0.2 GM57AA.
    Also, I wiped cache in recovery menu after update.
  4. Sandy9678
  5. julenardo
    Froyo Dec 2, 2019
    julenardo , via OnePlus 7 , Dec 2, 2019 :
    After upgrading to 10.0.2 I notice higher battery draining during standby at night. Before the update it lost about 4%, while it is now after the update about 8%.
    Also SOT has reduced from average 6 hours down to 5 hours.
    The battery stats does not show any noticeable problems, just Android system seems to consume slightly more.
    Any suggestions for getting more details about the backup, maybe with 3rd party app?
    Thank you.
  6. H1570196076554
    Cupcake Dec 2, 2019
    H1570196076554 , Dec 2, 2019 :
    I am not getting latest updates in my oneplus 7 what to do and please solve this problem I updated this in oxygen updater app please solve this team oneplus..[e]1f614[/e][e]1f614[/e]
  7. Jav P
    Gingerbread Dec 2, 2019
    Jav P , Dec 2, 2019 :
    You could create a widget for the notification log and see if that sound left a record in there showing which app caused it. Long press home screen - widgets - scroll down until you find Settings - drag it and select Notification log from that list. Tap the new widget right after you get that sound again.
  8. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 2, 2019 :
    If nothing can explain it if you look here I don't know what it can be.
    Any recent app or function you recently tried? Step counter or anything? Still it should still show something somewhere if it makes a noise.
    If you reset app preferences it should also reset notification setting I believe.
    Or maybe there is some explaination here.
  9. Sandy9678
    Sandy9678 , via OnePlus 7 , Dec 2, 2019 :
    This sounds great, I'll try it bro.
  10. Sandy9678
    Bro, there was no notification when I saw after hearing it. And Moreover it comes even when data and wifi are off. I did alter any settings or any particular app's preferences.. In the evening, i just played with customization which is in settings app. That's it. Don't know how this shit got triggered. It's soo annoying. And 4 out of 5 times it comes when screen is off.. even without any internet connection.
  11. Sandy9678
    I did not alter***
  12. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 2, 2019 :
    Not sure what widget you are referring to. It does not show up when using Niagara launcher in beta 6 atleast.
    Anyway... Here is a logger tool
    https://play.google.com/store/apps/details?id=com.ikvaesolutions.notificationhistorylog
  13. Sandy9678
    Jav P likes this.
  14. Sandy9678
    Yes bro, I'll try it. I hope this thing will record all notifications.. coz that sound comes mostly when screen is off.. so chances are that I might miss. Hopefully, this widget will record it.
  15. arun1092
    Froyo Dec 2, 2019
  16. Sandy9678
    And yes bro, I have set diff notification tunes for diff apps.. which I can easily recognize since iam used to it. But I never heard this tune from any app notifications.. nor any system notifications. This is first time I heard it. It's something similar to the tune which appears when we disconnect a call.. yea, almost similar.. yet different.
  17. Sailor Moon
    Donut Dec 2, 2019
    Sailor Moon , Dec 2, 2019 :
    [QUOTE = "Sandy9678, сообщение: 21099130, участник: 2139506"] Да, братан, я попробую. Я надеюсь, что эта вещь будет записывать все уведомления ... потому что звук идет в основном, когда экран выключен ... так что есть вероятность, что я могу пропустить. Надеюсь, этот виджет запишет его. [/ QUOTE]
    У меня была такая проблема, в этом меню видны уведомления, зайдите сразу после звука и посмотрите, какое приложение вызвало
