350
OxygenOS 10.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. skmathukumalli
    Cupcake Dec 3, 2019
  2. Sandy9678
    Honeycomb Dec 3, 2019
    Sandy9678 , via OnePlus 7 , Dec 3, 2019 :
    Okay.. so now I have cleared cache and data of NFC, also force stopped it. Let's see.
  3. sunit2gupta
    Cupcake Dec 3, 2019
    sunit2gupta , Dec 3, 2019 :
    After getting this update..wide angle mode in photo and night mode is different.. in normal photo section wide angle is not giving you a proper difference in terms of normal mode.. please fix this issue.
  4. RaghwendraPratap
    Eclair Dec 3, 2019
    RaghwendraPratap , Dec 3, 2019 :
    Worst update ever
    Wifi automatically turns on
    Flight mode automatically turn on
    Phone has heating issue
    Pathetic Service one plus[e]1f623[/e][e]1f623[/e]
  5. IvanSap
    Donut Dec 3, 2019
  6. I1561546882857
    Froyo Dec 3, 2019
    I1561546882857 , via OnePlus 7 , Dec 3, 2019 :
    I have no issues which you have noticed!
    I guess you should factory reset your device once!
    for me this software works all fine, has minimal issues which should hopefully be resolved in the next update!
    IvanSap and S1568815383150 like this.
  7. S1547957605819
    Cupcake Dec 3, 2019
    S1547957605819 , via OnePlus 7 , Dec 3, 2019 :
    I got the update last night but I chose not to download it and wait till the morning. In the morning when I tried to update , it showed no available updates are there. Did this happen with someone else and what's the reason behind this?
  8. raj_232009
    Cupcake Dec 3, 2019
  9. _Jagadeesh_KB_
    Cupcake Dec 3, 2019
    _Jagadeesh_KB_ , Dec 3, 2019 :
    After this update my phone is hanging during chrome and gaming mode usage.
    fingerprint doesn't appear sometimes. Battery drain quickly.
    NOT HAPPY WITH THE UPDATE!
    PLEASE FIX THE ISSUE!
  10. prasenjeetsinha
    Eclair Dec 3, 2019
    prasenjeetsinha , Dec 3, 2019 :
    I'm using icici bank imobile app... and it's running smoothly....
  11. Danu123
    Cupcake Dec 3, 2019
  12. akks
    Jelly Bean Dec 3, 2019
    akks , Dec 3, 2019 :
    You should wait for that option to come again
  13. akks
    Try clearing storage of camera and re set it up
  14. akks
    For such software issues, hard reset is the best way out. Do it after backing up your data, if you haven't done yet
  15. akks
    Try deleting the .OTA hidden folder in internal storage, restart and check for update again. If still not getting notification, you need to wait
  16. akks
    Yes. Q1, 2020
  17. akks
    You can convert it to international version, i guess. Please search in the forum or wait for someone else to guide you better
    S1568815383150 likes this.
  18. hally79
    Eclair Dec 3, 2019
