350
OxygenOS 10.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. RaghwendraPratap
    Eclair Dec 3, 2019
    RaghwendraPratap , Dec 3, 2019 :
    First of all you mind your language , i am an oneplus user and if i will face any issue i will just report it . Who the hell are you to say me like this?
    Georgeoneplus7pro and Vivek_SV like this.
  2. Marcstang04
    Gingerbread Dec 3, 2019
    Marcstang04 , Dec 3, 2019 :
    Beta probably later this week, stable mid to late December.
  3. X1568888095586
    Cupcake Dec 3, 2019
    X1568888095586 , via OnePlus 7 Pro , Dec 3, 2019 :
    hello I'm the user of OP 7 pro, my variant is 8,256 gb & my device version is GM 21 BA10.0.2. I want to know you that for stable version user as like me when we will get Nov'19 patch update with call recording feature enabled ? already beta 6 version users got Nov'19 patch update with call recording option.So I am asking you about Nov'19 patch update through Oxygen updater, is it possible to tell exact date for Stable version security patch update? Another thing I want to know that for camera section in OP 7 pro macro mode will be add or not?
  4. B k
    Ice Cream Sandwich Dec 3, 2019
    B k , via OnePlus 7 Pro , Dec 3, 2019 :
    yes beta6 comes with November security patch. next stable or beta can be of november or december security patch
    u can download from oxygen updater, no difference in updates or patches as firmwares are from one plus servers
    macro mode will not come to 7 series, never
    its a hardware limitation. [e]1f609[/e][e]1f44d[/e]
  5. B k
    and yes, i forgot.. call recording
    i m not sure, but i think its region wise. in india option is available
  6. X1568888095586
    Cupcake Dec 3, 2019
    thanks for your feedback in this regards.But please ensure us stable user will get Nov'19 or Dec'19 patch update & can we get Call record feature?Ok Macro mode sacrificed bt do you think any update required for camera section in OP 7 pro? And please add the option in contact list display with phn number
    B k likes this.
  7. Partha Barman
    Cupcake Dec 3, 2019
  8. akks
    Jelly Bean Dec 3, 2019
    akks , Dec 3, 2019 :
    Go to apps and force stop digital wellbeing, there. If it's from that, notification tone should go..
    Another chance is that is it any broadcast message? Search broadcast in settings and switch it off.
  9. akks
    Around 2 months after the present one.
    Bi monthly updates in OnePlus
    dubbaYous likes this.
  10. JudePatrick
    Cupcake Dec 3, 2019
  11. barnabyj
    Honeycomb Dec 3, 2019
    barnabyj , via OnePlus 7 Pro , Dec 3, 2019 :
    while there are other options available, I shouldn't have to use a 3rd party app to update my phone, 10.0.2 isn't listed on the OnePlus site yet, and at the end of the day if they are not pushing the update out to everyone, what does that say about their own confidence in it? I myself am not complaining here, I'm just curious as to what the situation is, as if OnePlus isn't about to push it out over OTA, that doesn't really make me feel confident in it either.
  12. Legend189
    Froyo Dec 3, 2019
  13. F1559829424964
    Donut Dec 3, 2019
    F1559829424964 , Dec 3, 2019 :
    we can use , i am using it after updation.
  14. F1559829424964
    Donut Dec 3, 2019
    everything is quite okay, but need to improve in camera section which is more important part of this phone, OP7 camera has less quality and pixels problem.
  15. yangchenxi0606
    Cupcake Dec 3, 2019
    yangchenxi0606 , via OnePlus 7 Pro , Dec 3, 2019 :
    Wow, that's really an adventure for me, but thank you all the same. Maybe this answer would help some other mates. Good contribution.
  16. Sandy9678
    Sandy9678 , via OnePlus 7 , Dec 3, 2019 :
    I did force stop digital wellbeing bro.. it dint work.
    And which broadcast among this bro?
  17. Sandy9678
    Bro, what is this "handling theme" under Android system? Saw this thrice now within few hours. I dint get any notification about it.. but it's there under notification log.
  18. akks
    You mean, notification sound used to come even after force stopping Digital well-being? If so, isn't it less likely from that app?.
    I meant check if that emergency alerts are on, if so disable them
  19. Sandy9678
    Yep, that tune is still there even after force stopping Digital wellbeing.
    Ok, so now I've disabled emergency alerts too.. let's see.
  20. Jav P
    Froyo Dec 3, 2019
    Jav P , Dec 3, 2019 :
    Nothing to worry about. I got them from time to time and always in pairs. I think it's just the system adapting to any theme or customisation that you enabled.
