354
OxygenOS 10.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. docnok63
    Jelly Bean Dec 5, 2019
    docnok63 , Dec 5, 2019 :
    Never. They are two different channels. Beta will only get Beta updates. Stable will only only get Stable updates. You can only channels without data loss when the opposite channel is newer than the current channel (or you're rooted with TWRP.) Right now Beta is newer than Stable by two days, so this is not possible. You'd have to revert to Pie and then upgrade to Stable (or use a fastboot installer to skip revert.)
    Go into Customization\FP animation, all the way to the right and turn off animation, and wait for OP fix in changelog.
    Best guess is end of this month/beginning of next month for holiday present.
    Georgeoneplus7pro likes this.
  2. Dgafking0480
    Ice Cream Sandwich Dec 5, 2019
  3. docnok63
    Will do brother. Imma make an unboxing video and later a speedtest video and throw them on YT....minus the McLaren :(
    Dgafking0480 likes this.
  4. G_Nicholas_Watson_DMuT
    Donut Dec 6, 2019
    G_Nicholas_Watson_DMuT , Dec 6, 2019 :
    Had no real problems with Android 10 or 10.1
    Maybe 3rd time unlucky as I'm getting a much faster battery drain on latest 10.2
  5. Kishor_c
    Donut Dec 6, 2019
    Kishor_c , via OnePlus 7 , Dec 6, 2019 :
    using OnePlus 7 and i noticed alaram application is not working bas expect. is everyone facing same issue after this update ?
  6. LaxmanS
    Cupcake Dec 6, 2019
    LaxmanS , via OnePlus 7 , Dec 6, 2019 :
    i got an update the day before yesterday. i set it for update but my internet suddenly went off. and it was interrupted. later on i tried it again but my system says it is up to date with version 10.1? what might had happened any idea. ok its staged roll out but my turn had come and went off????
  7. Sahil_lihas
    Gingerbread Dec 6, 2019
    Sahil_lihas , via OnePlus 7 , Dec 6, 2019 :
    use OxygenOs updater from playstore
  8. Amit_Agrawal_2005
    Cupcake Dec 6, 2019
  9. LaxmanS
    Cupcake Dec 6, 2019
    is it the same thing if i use oxygen updater and the update that comes to me officially? actually i had used it before and didnt face any problems but i doubt about the originality and the security. Many people had commented against it in many post. would is be wise to use the app or other way round?
  10. G_יואל_אשריאן_
    Cupcake Dec 6, 2019
  11. Dthaki
    Cupcake Dec 6, 2019
    Dthaki , Dec 6, 2019 :
    Is anyone else's phone getting quite hot while running Android Auto? I noticed as soon as I 'upgraded' to 10.0.2.
  12. _interceptor_
    Cupcake Dec 6, 2019
    _interceptor_ , via OnePlus 7 , Dec 6, 2019 :
    disable substratum (if any)
  13. Sourav_Pradhan0
    Cupcake Dec 6, 2019
  14. Q1558332564007
    Cupcake Dec 6, 2019
  15. jatin0990
  16. amolrudrake
    Cupcake Dec 6, 2019
    amolrudrake , Dec 6, 2019 :
    still I can't use my phone for car play or car Bluetooth connection for calling and receiving call
  17. Q1558332564007
    Cupcake Dec 6, 2019
  18. E1571760814834
    Cupcake Dec 6, 2019
  19. jatin0990
  20. prokai
    Cupcake Dec 6, 2019
    X1571370006821 likes this.
