354
OxygenOS 10.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. Nicu2
    Donut Dec 6, 2019
    Nicu2 , via OnePlus 7 Pro , Dec 6, 2019 :
    X1568888095586
    bro, can this feature will be add in our OP 7 pro by OnePlus? Specially separate sound settings for video song & audio​
    In settings are separate but sometimes when i lower the volume when playing movies or music, it lowers also the volume for ringtone.
    Georgeoneplus7pro likes this.
  2. dubbaYous
    Ice Cream Sandwich Dec 6, 2019
    dubbaYous , via OnePlus 7 Pro Nebula Blue , Dec 6, 2019 :
    Best thing to do is use oxygen updater, I had to go that route otherwise I would still be on 9.5.13 as well. I am from Ohio. I have the same problem with my op 6 as well.
    David Turney likes this.
  3. tpatrick66
    Cupcake Dec 6, 2019
  4. Wilberforcezen
    Cupcake Dec 6, 2019
    Wilberforcezen , via OnePlus 7 Pro , Dec 6, 2019 :
    It's not a beta. It's on oneplus' official site available for download. But sure, you can also wait for the OTA.
  5. guru3583
    Cupcake Dec 6, 2019
    guru3583 , Dec 6, 2019 :
    Fingerprint sensor stopped working for apps after latest 10.0.2.GM57AA update. It was working perfectly before that for my OnePlus 7.
    I1571976381719 and pateltanmay like this.
  6. Sergioaddo
    Froyo Dec 6, 2019
    Sergioaddo , Dec 6, 2019 :
    see the issue has been this lag... the after effect of fingerprint scanner animation... it can even be visible after the screen gets unlocked. It is not that i haven't tried wiping cache or factory reset. This has been reported by many and the problem started after A 10
  7. silmax89
    Cupcake Dec 6, 2019
    silmax89 , Dec 6, 2019 :
    The worst that can exist is to buy any oneplus T-Mobile version cell phone. My phone has the September security patch and is not updated for more than I try
    it manually. while users of oneplus 7pro international version can get Android 10.
  8. Swejuggalo
    Community Bug Hunter Dec 6, 2019
    Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 6, 2019 :
    I think I've seen it exclusively on 7. I don't know how many reports they got on this.
    I sent one on a other animation issue. It took rather many attempts to get it replicated together with a video [e]1f609[/e] Hopefully it gets fixed eventually. It's pretty low down on priority list though.
  9. G_Nicholas_Watson_DMuT
    Eclair Dec 6, 2019
    G_Nicholas_Watson_DMuT , Dec 6, 2019 :
    I'm doing a little better. I get around 6 hrs SOT but that's with light usage.
    Even on 10.1 I was getting around 7.30 hrs (with similar pattern of use).
  10. Dgafking0480
    Dgafking0480 , via OnePlus 7 Pro , Dec 6, 2019 :
    this is bc tmo variant of the 7 pro hasn't received Android 10 update yet. it is still currently in beta form as their are testers with the tmo beta.
  11. LamarFrazier
    Froyo Dec 6, 2019
    LamarFrazier , Dec 6, 2019 :
    ok appreciate it. yea I'll give it another week and if they don't roll it out then I'll just download it from there then. thanks
  12. Jkanurag
    Cupcake Dec 6, 2019
  13. fiul777
    Cupcake Dec 6, 2019
    fiul777 , via OnePlus 3 , Dec 6, 2019 :
    hello everyone, my oneplus 7 pro started working hard, when i click to turn off wifi wait 5-7 seconds to close, do you have this problem too?
  14. AMIYA_KUMAR
    Cupcake Dec 6, 2019
    T1572757221961 likes this.
  15. Jdub670
    Cupcake Dec 6, 2019
    Jdub670 , Dec 6, 2019 :
    I just don't see why we aren't getting any OTA? I'm outside Vegas, OP7pro unlocked, and still on 9.5 as well. I could load it myself but I feel like when they announce that 10.0.1 is a staged rollout and it never comes and then they say the same with 10.0.2 and it still never comes, there must be a reason it's not being pushed by them, so I'm not keen to go find it myself and get into a buggy situation.... still wtf?
    dubbaYous likes this.
  16. V1524338339532
    Cupcake Dec 6, 2019
  17. cmgroft
    Cupcake Dec 6, 2019
    cmgroft , via OnePlus 7 Pro , Dec 6, 2019 :
    With this new update as anyone figured out to have pop-up notifications for apps like Twitter? New notifications just appear in my status bar
  18. idbl_fanatic1
    idbl_fanatic1 , Dec 6, 2019 :
    https://www.oneplus.com/support/softwareupgrade/details?code=PM1574156267635
  19. Marcstang04
    Gingerbread Dec 6, 2019
    Marcstang04 , Dec 6, 2019 :
    Downgrading will do a full factory reset, your phone will be like it was when it came out of the box. Use OnePlus Switch to do a backup, put that backup on your computer before downgrading.
    Shahid Hakkim likes this.
  20. docnok63
    Jelly Bean Dec 6, 2019
    docnok63 , Dec 6, 2019 :
    I want everyone who didn't believe me and trust the Oxygen Updater app or XDA links I posted earlier to look at the MD5 posted on the OnePlus site link above and look at the MD5 of the GM21AA 10.0.2 link posted on XDA over a month ago. As I've said all along, it's the SAME EXACT FILE coming from Amazon servers rented by OnePlus:
    https://forum.xda-developers.com/oneplus-7-pro/how-to/oneplus-7-pro-global-repo-oxygen-os-t3930585
    Y'all have been needlessly waiting on an OTA for no reason and could've done your local upgrade weeks ago like I and so many others did. You can use the same XDA link for the BA version which isn't even available on the OP site.
    EDIT: I was wrong a bit earlier and hadn't been paying much attention to our changelog, but now I see that our 10.0.2 includes:
    • Optimized the standby power consumption
    • Optimized the expanded screenshot feature
    • Optimized the Bluetooth connectivity in the automobiles
    • Improved system stability and general bug fixes
    So all that complaints that our build is waaaaaaaaayyyy behind the 7T series and that OP is paying special attention to their "new favorite device", it's just numerically behind in build numbers. It's completely caught up to 10.0.6 changelog:
    https://forums.oneplus.com/threads/oxygenos-10-0-6-for-the-oneplus-7t.1139786/
