353
OxygenOS 10.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. Poussin16
    Gingerbread Dec 10, 2019
    Poussin16 , via OnePlus 7 , Dec 10, 2019 :
    Prasadmaheshwari08
    Is anyone facing Bluetooth connection issue after this update? as i am facing it for connecting my wireless earphones,the connection just drops and at times there is wierd sound also suming in a ear phones.​
    hi
    I have checked now. for it seems better. faster for connection.
    Faden_art likes this.
  2. VIJAY216
    Honeycomb Dec 10, 2019
    VIJAY216 , Dec 10, 2019 :
    Font pronlem in lockscreen pin not solved in 10.0.3.Already submitted feedback multiple times after 10.0 update
  3. VIJAY216
  4. idbl_fanatic1
    Ice Cream Sandwich Dec 10, 2019
  5. Nic2112
    Nic2112 , Dec 10, 2019 :
    Security patches only is pretty much the only type of update you get with a pixel, except for the occasional new feature. At least on the Beta track for OnePlus, you get security updates and usually a new feature every update.
    Marcstang04 and docnok63 like this.
  6. VIJAY216
    don't you see usless white outer layer.Now please dont tell me to use 3rd party icon pack.
  7. idbl_fanatic1
    idbl_fanatic1 , Dec 10, 2019 :
    Oh, yeah, I guess it really never bothered me
  8. VIJAY216
    Its never bothered you doesn't means its not a issue.I know i am a nick picker.
  9. Nic2112
    I'm guessing the white circle around it.
  10. A1560648267550
  11. VIJAY216
    earlier its not even in pixel devices its normal
  12. A1560648267550
  13. VIJAY216
    ohhh !!!google apps is same in every phone.My samsung device has normal chrome icon(without white line)
  14. A1560648267550
    A1560648267550 , via OnePlus 7 Pro , Dec 10, 2019 :
    Samsung OS isn't Oxygen OS what you're calling a bug is something that is featured that way on Oxygen...can you explain why coincidentally all G-apps have the ring and it's not just Chrome?
  15. VIJAY216
    From the beginning apps other that chrome has white ring irrespective of device manufactures.Use Oxygen os with Pie chrome icon in that doesn't has white ring.
  16. A1560648267550
    Once again you are talking about another Android version...pie over 10, you're not considering they have done this for visuals to separate the G-apps from other apps in just Android 10. That's why when you change the icon pack it changes cause it's not a bug they did it on purpose
  17. VIJAY216
    what a lame answer to justify yourself.Haha.Factory reset your phone once and see it backs to normal.
  18. A1560648267550
    So if factory reset fixes it why are you asking them to "fix" the bug if you already know how? Dumbass
  19. VIJAY216
    actually the problem is in some time 5min,1hr or 1 days it change to white ring
  20. U1576006686408
    Cupcake Dec 10, 2019
