353
OxygenOS 10.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. VIJAY216
    Honeycomb Dec 10, 2019
    VIJAY216 , Dec 10, 2019 :
    So according to you new Files app and Duo is now owned by Oneplus.Haha
  2. VIJAY216
    even Maps.hahahaha
  3. A1560648267550
    Gingerbread Dec 10, 2019
    A1560648267550 , via OnePlus 7 Pro , Dec 10, 2019 :
    LMFAO..ok bro you're beyond hilarious, mines been white the whole time I've used the phone....well good luck with your interchangeable white ring I hope it does not cause you to go thru Ragnarok, or is a beacon to have aliens probe you. :)
  4. VIJAY216
    Ok but what about your lame answer that OnePlus doing it to seprate Google apps....Files,duo,maps doesn't has it even in Oxygen os 10
  5. A1560648267550
    Duos is integrated into OnePlus dialer....did you forget this?
    Maps is integrated into OnePlus Launcher parking Feature...did you forget that?
    Shall I continue or are you starting to see a trend?
  6. A1560648267550
    It's not lame now you're trying to find a justification that if you've read thru their publications you would know these are not bugs...have a great day!
  7. VIJAY216
    so integrated means its now owned by Oneplus.By the way it just using Google services to provide better functionality.If we keep aside duo and maps for a movement what about files app
  8. A1560648267550
    I never said they were owned, you did...If they are modified specifically for the OS hence they wouldn't fall under the category of GApps. Last but not least, Google has created a NEW files app that comes preloaded on Pixel Devices that means the Files app you believe is Google isn't the one that is part of GApps. Anymore questions?
  9. A1560648267550
    You say keep aside certain apps but you brought up these apps, my point is out of all of this the White ring you're complaining about isn't a bug so download a new icon pack and move on bro. Like seriously
  10. x_jayreghe_x
    x_jayreghe_x , via OnePlus 7 , Dec 10, 2019 :
    Which update
  11. VIJAY216
    You earlier said that oneplus doing this to differentiate google apps and all the apps i am talking about even Files app is owned, developed and maintain by google itself it just Oneplus fault that they unable to fix Chrome icon Ui
  12. VIJAY216
    Already told don't give me advice to use third-party icon pack
  13. A1560648267550
    I said Google owns pixel phones that's why they don't need to differentiate the apps, never said OnePlus owned anything and now I truly know I have wasted my time and the poor time of the people who have to read thru this conversation. You obviously have OCD so I hope the white ring of chrome despair burns out your corneas in a fashion that shalt make Odin proud....oh and one last thing...
    ICON PACK FIXES EVERYTHING!!!!
  14. VIJAY216
    I don't want to use so please don't advice me.its you giving lame answers first.When i compared it with other icon packs you simply started story of integration in os.
  15. Sumit393
    Eclair Dec 10, 2019
  16. VIJAY216
    and gn man because i don't have free time like you to waste
  17. Marcstang04
    Marcstang04 , Dec 10, 2019 :
    A lot of these people probably never owned a Pixel device(I had two, still have one), this is what you got each month, 75-100mb's. Maybe I should complain to Google, my backup phone a Pixel 3XL is still on the November Security patch.
  18. Sumit393
    Eclair Dec 10, 2019
    Sumit393 , Dec 10, 2019 :
    download it from the updater app.
  19. docnok63
    Jelly Bean Dec 10, 2019
    docnok63 , Dec 10, 2019 :
    I mean if they're going to complain about a security patch release, the post should say, "WHY ISN"T IT DECEMBER SECURITY PATCH?!?!?!??????????" There, I did it for them :p:rolleyes::p
    Georgeoneplus7pro likes this.
