354
OxygenOS 10.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. svntsvn
    Eclair Nov 20, 2019
    svntsvn , via OnePlus 7 Pro , Nov 20, 2019 :
    It should but you'll have to wait.
    Just update again from oxygen updater, I select full update Every time to get everything updated. Don't worry about your data it'll remain when you're updating on the same stable channel. Although I haven't before, id also not use a VPN and check the file to make sure it's appropriate to your region.
    If you have issues, just start with wiping caches in recovery or app settings, resetting network settings before factory resetting. I can definitely tell my wifi and network is more stable with update, go get ya some
  2. svntsvn
    Eclair Nov 20, 2019
  3. uddinnasir
    Froyo Nov 20, 2019
  4. Sahil_lihas
    Honeycomb Nov 20, 2019
  5. zix47
    Gingerbread Nov 20, 2019
    Y1560292458835 likes this.
  6. Subbarao.B
    Cupcake Nov 20, 2019
  7. zix47
    zix47 , Nov 20, 2019 :
    we already got android 10.0.1 update, its 10.0.2
  8. iamraj21
  9. K1570552543293
    K1570552543293 , Nov 20, 2019 :
    I have oneplus7 but no update is shown I have 10.0.1 when 10.0.2 will come in my phone tell me OnePlus team
  10. ROHINI25
    Eclair Nov 20, 2019
    ROHINI25 , via OnePlus 7 Pro , Nov 20, 2019 :
    anybody facing battery draining issue. all my setting kept to low like resolution and refresh rate and i have also kept to one sim. still battery drain like any thing. SOT IS MOST LIKELY 2.5HRS ONLY.
    Any suggestions why is it so?
  11. RAJHESHBABU
    svntsvn likes this.
  12. Z1562043472918
  13. zix47
    it's whatsapp update ig
  14. zix47
    well it never happened to me, you should go to customer care
  15. ROHINI25
    Eclair Nov 20, 2019
  16. zix47
    nope its in OnePlus 7 pro and 7t, 7 is working fine and there was news about it from where i know about it
  17. ajaypawar
    Eclair Nov 20, 2019
    ajaypawar , Nov 20, 2019 :
    it's there just two comment before [e]1f604[/e]
  18. kpcivil22
    kpcivil22 , via OnePlus 7 , Nov 20, 2019 :
    use oxygen Updater
