354
OxygenOS 10.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. B k
    Ice Cream Sandwich Nov 19, 2019
    B k , via OnePlus 7 Pro , Nov 19, 2019 :
    yes calculator ui is fixed.. just like pie.[e]1f44d[/e]
    #61
    Petko_Antonov likes this.
  2. B k
    kinda fixed, yes better than 10.0.1, but still needs time
    #62
  3. I1561546882857
    Gingerbread Nov 19, 2019
    #63
    mahekparmar and farazk3 like this.
  4. #64
  5. B k
    #65
  6. #66
    y.karsoliya likes this.
  7. dasza1965
    dasza1965 , Nov 19, 2019 :
    It will be great if you will add any notifications at the lock mode. There's no info about charging, notifications - you promote to do breakes during playing games but you want us to check phone each few minutes to find out - are there any notifications.
    E.g. it will be excellent if Horizon Light will work as notifications.
    #67
  8. PlusUn
    Froyo Nov 19, 2019
    #68
  9. U1561359547176
    Donut Nov 19, 2019
    U1561359547176 , via OnePlus 7 , Nov 19, 2019 :
    Was not able to play Pubg or COD because of the heating issue till now..
    the phone heated up to absurd temperature after I updated to Android 10.
    Hope this update resolves that issue
    #69
    ShaikAHMEd2997, 2297 and Shalin235 like this.
  10. ADMOrange
    Froyo Nov 19, 2019
    ADMOrange , via OnePlus 7 , Nov 19, 2019 :
    Im afraid you will delete all your files in the process of installing Official build from Beta build.. thats how it goes brother.
    #70
  11. aziz_nurse , via OnePlus 7 Mirror Gray , Nov 19, 2019 :
    [e]1f62d[/e][e]1f62d[/e] any other solution?
    #71
  12. B k
    yes u can.. download link from xda or oxygen updater..
    use local upgrade from system updates.
    u can flash it.. u will loose ur data. so BACKUP
    #72
    pintukundu97 likes this.
  13. Zackeroo
    Zackeroo , Nov 19, 2019 :
    Don't worry... You aren't missing out on much.
    It is quite amazing at stability but it forces you to use 1080P and also can become very blurry when moving the phone
    #73
    mahekparmar likes this.
  14. Zackeroo
    Haha just u wait... This is Oxygen OS while it's buggy... Once more updates start coming in to fix the bugs, Oxygen OS will shineeee
    #74
  15. Zackeroo
    That's weird... I just changed my live wallpaper about 10 minutes ago and it's moving completely fine. I am on the newest 10.0.2 update. Hmmm
    #75
    Deactivated User and B k like this.
  16. B k
    quote-
    you usually have to wait for that which is worth waiting for
    [e]1f609[/e][e]1f44d[/e]
    #76
  17. Zackeroo
    Yea i'm quite liking this new update. Updated in the morning... Now it's night here. Battery life did quite well... I know I can trust OnePlus to provide updates which are going to fix all these bugs :)
    #77
    B k likes this.
  18. Sujknair
    #78
    V1rTu likes this.
  19. Zackeroo
    I just ran through a whole day with this update and i'll give you a quick overview
    Battery life:
    So far, battery life hasn't really increased too much. There might be a slight increase but nothing too noticeable. Battery was 100% in the morning and is now 27% after 3 hours 30 minutes of Extreme Heavy Usage (Maps, camera, multitasking, Snapchat, Instagram, lots of battery hungry apps). I do find this quite low however, it lasts for my day even with the QHD+ 90Hz options set.
    Heating issues:
    I never had major heating issues in the first place BUT today I used my phone heavy and probably maxed out the CPU quite often. The phone work seamlessly and did an amazing job at managing multitasking like the absolute beast it is. The phone ran in 35C heat (95F) and didn't have any heating issues. I'm not sure if this was the update that helped or what
    #79
  20. #80
