354
OxygenOS 10.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. B k
    Ice Cream Sandwich Nov 20, 2019
    B k , via OnePlus 7 Pro , Nov 20, 2019 :
    yes go ahead. better than 10.0.1 and ob5
    many major issues are solved.
    talking abt insta and whatsapp, not everythings on OP. apps too needs to be optimised for a10 support [e]1f609[/e][e]1f44d[/e]
    david90531 likes this.
  2. glenngaucigrech
    Cupcake Nov 20, 2019
  3. david90531
    Froyo Nov 20, 2019
    david90531 , via OnePlus 7 Pro , Nov 20, 2019 :
    Thumbnail seems good now! Will see about the RAM problem... Games getting closed all the time is pretty annoying
    B k likes this.
  4. csgoaditya
    Froyo Nov 20, 2019
    csgoaditya , via OnePlus 7 , Nov 20, 2019 :
    It's only available in phones with triple camera setup.
  5. csgoaditya
    Froyo Nov 20, 2019
    No. You will not lose any of your data after updating. [e]1f609[/e]
  6. K1560339751698 likes this.
  7. B k
    dont know bro.. one plus may be working on it..
    may launch with 8/8 pro models
  8. B1571500439457
    B1571500439457 , Nov 20, 2019 :
    i have that version. Well maybe i need to restart the phone or double check other issues that cause this problem. Thanks
    B k likes this.
  9. B k
    K1560339751698 and Petko_Antonov like this.
  10. B k
    yes try restart.. if u are facing issues with many other apps try factory reset
  11. csgoaditya
    Froyo Nov 20, 2019
    It's stagged rollout. You will get it in few days.
    K1571457170536 likes this.
  12. K1559667886575
  13. josejohna
  14. K1560339751698
    K1560339751698 , Nov 20, 2019 :
    when is the 10.0.2. update coming to India? On Oneplus7pro
    R1565758971683 likes this.
  15. B k
    its released.. but staged rollout. few users get it and if no major bug found, then global.
    2 weeks is the time in staged rollout..
    so kindly wait or u can use oxygen updater app[e]1f44d[/e][e]1f44d[/e]
  16. csgoaditya
    Froyo Nov 20, 2019
    Download Oxygen Updater from play store. I will not recommend to do this. But if you want update now then you can.
  17. csgoaditya
    Froyo Nov 20, 2019
    You can directly update to 10.0.2
  18. csgoaditya
    Froyo Nov 20, 2019
