354
OxygenOS 10.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. donPepitoGrillo
    Ice Cream Sandwich Nov 20, 2019
    donPepitoGrillo , Nov 20, 2019 :
    Then do not post something that is not related to this thread, please.
    c.pister likes this.
  2. X1533891563315
    Cupcake Nov 20, 2019
  3. X1533891563315
    X1533891563315 , Nov 20, 2019 :
    same here
  4. Alfa Xavier
    Gingerbread Nov 20, 2019
    Alfa Xavier , Nov 20, 2019 :
    2) turn off the navigation bar feature... It's not a bug, but it's the design, hopefully they will address it in next update... I use side navigation gestures and bottom navigation is only used for assistant and minimizing windows.
    3) What you mean by home button white while watching movies? I have not had this issue after I found that it's only a single tap somewhere around the screen which is required to hide the navigation bars and controls in the app.
    4) For your information, Android 10 has said goodbye to the Android Webview, and if you have any doubt, please read articles in Google discover related to Android Webview in Android 10 where it says it no longer needs a seperate app from playstore, but it is already embedded in apps which support the same in Android 10.
    5) I don't see that as a bug. Please grow up kid. It's not a great deal and you're not going to report that as a bug because it's called the default skin tones of specific OSes. And as far as I'm concerned Oxygen OS won't give you flavours as it's the vanilla version with decent amount of freedom.
    donPepitoGrillo likes this.
  5. J1508070026278
  6. Vitalm
    Vitalm , Nov 20, 2019 :
    Hi there
    after update 10.0.2 file transfer not work with pc
    is anyone have same issue ?
  7. Alfa Xavier
    For your information, the regular Google Pay is the one which resembles the older Tez app which is the current Android Pay app in India as of now. The other one is a more advanced version of Google Pay which is currently not accessible in India as the process of implementation needs time.
    Explaining the second Google Pay, which does not resemble the older Tez app, is the one which in "other countries" is used as Google Pay (a.k.a Android Pay) where you can add your credit/debit card information in the app and use NFC technology to pay (using your phone instead of card) just like Samsung Pay or Apple Pay... Unfortunately it's currently not accepted by banks in India and in near future it will get implemented... So just if you find it irritating to see both apps, just identity the NFC based GPay and disable it in App Settings of your One Plus phone.
  8. donPepitoGrillo
    and the user says at the end "if possible can someone please report these issues?". Oh my god, what a kid
    Alfa Xavier and c.pister like this.
  9. donPepitoGrillo
  10. F1571668402475
  11. Sahil_lihas
    Sahil_lihas , via OnePlus 7 , Nov 20, 2019 :
    don't upload logs here, anyone can use your private data
  12. jim.kanaris
    Froyo Nov 20, 2019
    B1556444984933 likes this.
  13. uddinnasir
    Froyo Nov 20, 2019
  14. donPepitoGrillo
    then try a factory reset and charging during ALL night the next 2-3 days.
  15. Ankur_1405
    Eclair Nov 20, 2019
  16. IamRahul23
    Eclair Nov 20, 2019
  17. Omprakash98
    Omprakash98 , via OnePlus 7 , Nov 20, 2019 :
    i have updated my one plus 7 to above mentioned oxygen os 1month back but recently i dont know why battery life has drastically decreased. i never a heavy user how i used before similarly i am using it now also but why battery draining quickly
    Sumedh_Nadgir likes this.
  18. C1574253642462
    C1574253642462 , via OnePlus 7 , Nov 20, 2019 :
    I am using my oneplus 7 from 2 months now. I started to notice this issue now. Whenever I open the camera and after clicking some pics, it just become unresponsive and blank screen for a few moments and after that it says that camera stopped working? Whats the problem? Can you help me out? Btw I am using the 6gb variant running on latest oxygen 10.0.1 update and I have 63 gb of storage left. Please help me out [e]1f64f[/e]
  19. Sumedh_Nadgir
    Sumedh_Nadgir , via OnePlus 7 , Nov 20, 2019 :
    It uses ultrawide lense for the feature
  20. V1573462886684
