354
OxygenOS 10.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. Nilamber M
    Eclair Nov 20, 2019
    Nilamber M , Nov 20, 2019 :
    I don't think you can get that much of SOT. May be the users charge thier device multiple times. If you don't charge device beyond 90 (I think) the battery usage info doesn't get reset!
  2. Imrankhan6055
    Gingerbread Nov 20, 2019
    Imrankhan6055 , via OnePlus 7 Pro , Nov 20, 2019 :
    Perform a clean install. If the issue still persist you need to visit the service center ASAP.
  3. Abhishek1603
    Donut Nov 20, 2019
    G1559901600613 and ProsaicGiant like this.
  4. ujjawal_05
    Eclair Nov 20, 2019
    ujjawal_05 , via OnePlus 7 Pro , Nov 20, 2019 :
    Yes i know. I am only talking about SOT post once charge only
  5. sarkar.yog
    Donut Nov 20, 2019
  6. Imrankhan6055
  7. ujjawal_05
    Eclair Nov 20, 2019
  8. Rockingbks
    ProsaicGiant likes this.
  9. donPepitoGrillo
    Ice Cream Sandwich Nov 20, 2019
    donPepitoGrillo , Nov 20, 2019 :
    Remember: there are a lot of variables like screen bright level, network strength, number of accounts configured, apps, etc. And your SOT will be higher if you use your phone continuously instead of during small sessions.
    T1572757221961 likes this.
  10. donPepitoGrillo
  11. Imrankhan6055
    Try clearing the cache if that didn't help.Reset your mobile [e]1f4f1[/e] and see that helps.because the battery is improved alot in this update. I have attached my current usage.i played for 30min still the battery backup is good.If nothing helps i request you to visit nearby service center they will fix the issue within a hour!
  12. X1554211828531
    X1554211828531 , via OnePlus 7 , Nov 20, 2019 :
    it's only available for wide angle we only have primary and a dept sensor so don't except that feature
  13. ujjawal_05
    Eclair Nov 20, 2019
    Hmmm yes right. Yeah i know i get better sot if im continuosly using the phone, just i dont get the kind of numbers some of the users have posted on here
  14. Imrankhan6055
    donPepitoGrillo likes this.
  15. Ajay@1828
    Cupcake Nov 20, 2019
    MuthukumarR15 likes this.
  16. Jameszhe
    Donut Nov 20, 2019
  17. ujjawal_05
    Eclair Nov 20, 2019
    donPepitoGrillo and ProsaicGiant like this.
