354
OxygenOS 10.0.2 for the OnePlus 7 Pro and OnePlus 7
  1. the inspector
    Froyo Nov 22, 2019
  2. James 007
    Gingerbread Nov 23, 2019
    Soulsurfer919 likes this.
  3. Lone.survivor
    Cupcake Nov 23, 2019
    vinit nagool likes this.
  4. kanagaraj1010
    Ice Cream Sandwich Nov 23, 2019
    kanagaraj1010 , via OnePlus 7 Pro , Nov 23, 2019 :
    in pie update in normal usage I got 7 HRS But after Android 10 update I am getting only 5 to 6 hrs and that to after 10.0.2 update needs improvements much more in battery section
    after 10.0.2
  5. anveshtalluri89
    Eclair Nov 23, 2019
    anveshtalluri89 , via OnePlus 7 , Nov 23, 2019 :
    Standby battery draining behaviour is different. On first day of update it had taken 2 % of batter hole night. But after one day of usage its draining 5% on draining.
    Note: I had make clean and fresh installation after this update.
    Can anyone tell the best way of charging Cycle Maintenance.
  6. kanagaraj1010
    wait for couple of days so that it's gets optimized and then chk it or do wipe data and clear cache and check after that
  7. Deepanshu_Gusain94
    Deepanshu_Gusain94 , Nov 23, 2019 :
    By default " tap the screen to show " is enabled. so if i go to gesture control and enable double tab to wake up device and later disable it, in that case "tap the screen to show" is not getting enabled by itself. we have to enable it manually, not sure if its a bug or not. m on 10.0.1.
  8. XxvEnKaTxX
    Eclair Nov 23, 2019
    XxvEnKaTxX , via OnePlus 7 , Nov 23, 2019 :
    After 10.0.2 update Heavy battery drain , Slow charging ( When it comes to 90% Charging is automatically stops. don't its hardware issue or software )
    I found this bug After 10.0.2
  9. K1561124058231
  10. dcarlospc
    Donut Nov 23, 2019
  11. Bernest44
    Bernest44 , via OnePlus 7 Pro , Nov 23, 2019 :
    Now...I'm guessing Beta6 is a fix to 10.0.2?? I've had no issues except when I power off or restart.......it makes me push the power button a few times to access on screen log in. Hoping for a few of the seasoned pros to advise? [e]1f601[/e]
    RandyManLB likes this.
  12. abhigd
  13. Prasenjeet.Sinha
    Froyo Nov 23, 2019
  14. P1571322192909
    P1571322192909 , via OnePlus 7 Pro , Nov 23, 2019 :
    I, like everyone I'm sure here, loves to update and modify our phone and thank you very much for allowing us the ability to do so. I have more issues now with the fingerprint unlock now. otherwise so far great update. ( I had no issues in 10.01)
  15. P1571322192909
  16. abhigd
    abhigd , Nov 23, 2019 :
    from where can i download it manually???
  17. Bernest44
  18. abhigd
  19. Bernest44
    I have never had RAM issues ever with this phone. It's a 256/8 version. One bad update...but OnePlus updates for me I think are all about doing it CORRECTLY.....then you get what you get
  20. Dileep.Hegde
    Eclair Nov 23, 2019
