259
OxygenOS 10.0.3 [EU] and 10.3.0 [Non-EU] for the OnePlus 7 Pro and OnePlus 7
  1. Rockingbks
    Gingerbread Dec 21, 2019
    Rockingbks , via OnePlus 7 Pro , Dec 21, 2019 :
    Need some response from anyone who knows it...
    what happens when we clear cache?
    how does it affect battery life?
    how and why OnePlus launcher uses battery
    even sometimes about 10 percent.
    what happens if we uninstall launcher
    how to minimize battery drain of launcher
    what is play services battery drain and how to minimize it
  2. Jkanurag
    Cupcake Dec 21, 2019
  3. mlodykaras
    Froyo Dec 21, 2019
    republik163 and Deeppurple2525 like this.
  4. atLeeroyJenkins
  5. Sadikh_S
    SandeshChinchapur likes this.
  6. encorejane
    encorejane , Dec 21, 2019 :
    The left and right to go back navigation option used to be such that only the bottom 75% on either side would activate the gesture. With this update, the entire left and right edges activate the gesture. This is rather very problematic, as I was depending on the top 25% for other functionalities in different apps, and now they don't work with the edge swipe ☹️.
    SandeshChinchapur and t0mv3r like this.
  7. Tijrus_Boruah_7
    Tijrus_Boruah_7 , Dec 21, 2019 :
    After updating to 10.0.3 , battery seems to drain fast .
    Not really sure what the difference however I have checked and analysis based on usage .
    Adg123456789 likes this.
  8. Jav P
    Honeycomb Dec 21, 2019
    Jav P , Dec 21, 2019 :
    - Cache files are used by the apps and system to store temporary info that improves performance and the use of your phone resources. If you delete them you won't lose any personal info and they will be created again as you use the same apps and processes.
    - Since these file will be created again this process will use more resources, including battery.
    - That's the stock launcher and it will run all the time even if you use a custom one.
    - If you use a custom launcher you will lose some functionality, like the Recent apps. If you only use the stock launcher disabling the OnePlus launcher will render your phone basically useless since that's the main app to interact with you.
    - The launcher will run all the time, using battery. A high battery usage is usually related to changes being made in your layout, widgets, etc. Difficult to give you a comprehensive answer, it will depend on your usage.
    - Play Services include many different view processes making impossible to know for sure what's happening on your particular case.
  9. 11.3111
    republik163 and Adg123456789 like this.
  10. Rogerini
  11. AhmedNour
  12. Adg123456789 likes this.
  13. P1571322192909
  14. Deeppurple2525
  15. Jav P
    No, AA is the Global/International version.
    Deeppurple2525 likes this.
  16. Mordicus1973
    Froyo Dec 21, 2019
    Mordicus1973 , via OnePlus 7 Pro , Dec 21, 2019 :
    It's not an issues, 1% per hour is fine, your phone is connected to a network, some apps do polling, you have some services in the background using network (mail, WhatsApp, messager...etc)
    Even without any apps running, the 4g network use battery. 1 percent per hour mean 100 hours. 100/24 = 4 days. what did you expect from a 4G smartphone ?
  17. mc-milan
    Froyo Dec 21, 2019
  18. Swejuggalo
    Community Bug Hunter Dec 21, 2019
    Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 21, 2019 :
    AA is International. A new update rolls out step by step. It has never rollout to everybody at once.
    Before 10.3.0 International had 10.0.3 too. You just need to wait.
    Deeppurple2525 and rishugupta09 like this.
  19. G_apurv_snehil_dJup
    Eclair Dec 21, 2019
    G_apurv_snehil_dJup , via OnePlus 7 , Dec 21, 2019 :
    what did you people do?
    now if i hide the notch, the status bar comes down and we lose screen area. Previously if we used to hide the notch,these status bar icons would stay away from the full-screen area,and would lie in the left and right of the notch,now it's just pathetic,give me my old feature back.
    It just shows a huge black bezel now.
