259
OxygenOS 10.0.3 [EU] and 10.3.0 [Non-EU] for the OnePlus 7 Pro and OnePlus 7
  1. Realtorvibes
    Cupcake Dec 23, 2019
    Realtorvibes , via OnePlus 7 Pro , Dec 23, 2019 :
    Thank you so much for reaching out. I was on 10.0.2 and biometrics were working perfectly till that point. I genuinely don't understand and imagine that something broke from the previous iteration to this. I tried clearing cache and then logging in to the banking apps again and I keep trying to activate the biometric but it won't allow me to on all apps. It works like a charm on my OnePlus 5T though. Flumoxxed here.
  2. Tusar121
  3. ronyjohn01
    Honeycomb Dec 23, 2019
  4. BonaMEAS
    Donut Dec 23, 2019
    BonaMEAS , Dec 23, 2019 :
    After update to 10.0.3. I got a problem:
    - The phone is shut down by itself twice a time.
    - Before I update, My phone lives 2days without charge. After I update, My phone lives 1days. Battery issues.
    - Software not able like before the update. Not feeling good with the last version.
    Does anyone has the same problem ?
  5. Swejuggalo
    OnePlus 9 Series Expert Community Expert Dec 23, 2019
    Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 23, 2019 :
    Ah. I see. Then it is not as simple as an 10 compabilty issue. With the recent import of issues seen on Pixel devices I assume a rebase of Android 10 has happened and causing some new compabilty issues.
    Realtorvibes likes this.
  6. G1559901600613
    Eclair Dec 23, 2019
  7. Last edited: Dec 23, 2019
  8. Dileep.Hegde
    Eclair Dec 23, 2019
    Dileep.Hegde , Dec 23, 2019 :
    please anyone reply for this
    is factory reset before update or after update to 10.3.0/any update is good?
    after update factory reset will clear the update logs .. that's ok
  9. Dileepvenkat
  10. me_pavan2329 , via OnePlus 7 Pro Nebula Blue , Dec 23, 2019 :
    R1570721549354
    after update factory reset will clear the update logs .. that's ok​
    after update, you can just clean cache for that choose option from recovery mode. "wipe cache data"
    it will clean the junk of apps... you should do in every update..that way u can install clean rom bro[e]1f60a[/e]
    R1570721549354 likes this.
  11. N1572420349099
    N1572420349099 , Dec 23, 2019 :
    yah same problem facing.
  12. iNsAnE_106
    Froyo Dec 23, 2019
    niteshk2019 likes this.
  13. Dileep.Hegde
    Eclair Dec 23, 2019
  14. [email protected]
  15. iNsAnE_106
    Froyo Dec 23, 2019
    iNsAnE_106 , via OnePlus 7 Pro , Dec 23, 2019 :
    * Would request you to clear cache from your phone. Following are the steps:
    1. Switch off your phone.
    2. Hold Vol down and power button together until the phone restarts.
    3. Select the language English or whatever your preferred language is.
    4. Select Wipe Data and Cache.
    5. Select Wipe Cache. ( Please don't select anything other than this )
    6. Reboot.
    * If the problem exists after this too then please visit the nearest service center and get your phone formatted with the factory settings of the Android version and then download Zip file of the latest update from One Plus website and perform a local upgrade.
    Hope this solves your problem.
    me_pavan2329 likes this.
  16. SulabhM
    Eclair Dec 23, 2019
  17. [email protected]
  18. SulabhM
    Eclair Dec 23, 2019
  19. [email protected]
