257
OxygenOS 10.0.3 [EU] and 10.3.0 [Non-EU] for the OnePlus 7 Pro and OnePlus 7
  1. H1571364553280
    Donut Dec 25, 2019
    H1571364553280 , Dec 25, 2019 :
    Mobile is heating up without even playing any games and the battery is draining fast. Even after 2 months OnePlus can't give us a stable version of Android 10. Really disappointed.
    Dirk66 likes this.
  2. Ammar malpara
    Cupcake Dec 25, 2019
  3. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 25, 2019 :
    Heat usually comes from some activity. How does it look in the battery stats? Nothing abnormal? For example huge drain caused by syncing to online storage or something else?
  4. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 25, 2019 :
    Seems to get triggered by voice for me sometime... Despite not saying the correct words. Don't think Oneplus can do anything about that.
    Have voice match on?
  5. G1577271090025
    G1577271090025 , Dec 25, 2019 :
    Rubbish! Don't OnePlus engineers know what needs to be tested before releasing an update?
    1. The APN setting is reset and the APN information that you added is deleted;
    2. The headphone equalization adjustment of the sound setting is invalid! The bass of the OnePlus Bluetooth headset 2 I bought before is just rubbish! At that time, I wanted to return the goods, because I did n’t return the goods because of the headphone balance adjustment. Now the headphone balance adjustment can't be used, and the OnePlus Bluetooth headphones became garbage! Givemy money back!Recall it!
  6. G1577271090025
    垃圾! 难道一加的工程师不知道在放出更新之前需要测试的吗?
    1,APN设置被重置,自己添加的APN信息被删除;
    2,声音设置的耳机均衡调节失效! 以前买的一加蓝牙耳机2的低音就是个垃圾! 当时想退货,就是因为有耳机均衡调节,才没退货,现在耳机均衡调节不能用了,一加蓝牙耳机成了垃圾!请召回它!
  7. Samuel abhi
    Eclair Dec 25, 2019
  8. Rajat jain16
    Donut Dec 25, 2019
    Rajat jain16 , Dec 25, 2019 :
    after this update my oneplus 7 is working fine but there are two problems battery is draining very fast and charging speed is reduced . Now it takes around 2 hrs to charge completely.
  9. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 25, 2019 :
    Checked how the apps behave? Huge drain = often heat = slower charging.
    Scroll abit higher up for my checklist. Might be helpful
    Rajat jain16 likes this.
  10. Chiragkhurana
    Eclair Dec 25, 2019
    Chiragkhurana , Dec 25, 2019 :
    Same
  11. Rajat jain16
    Donut Dec 25, 2019
    yes same
  12. Saibal1993
    Donut Dec 25, 2019
    Saibal1993 , Dec 25, 2019 :
    I hate notch in OnePlus 7.need that hide notch feature almost like Oxygen OS9.
    i know that OnePlus bring that feature on build version 10.3.0 but it's useless,that option moves everything like status bar into downwards, we don't need that,we love that old day style,need status bar on top for utilise more display ..just add three option OnePlus..
    1. show notch area (already present)
    2.Hide notch and everything bring little down(present on 10.3.0)
    3.show status bar on top notch area,and hide notch(like Oxygen OS9)
    chiragvadhavana likes this.
  13. chiragvadhavana
    Froyo Dec 25, 2019
    chiragvadhavana , via OnePlus 7 , Dec 25, 2019 :
    You are right, its need for OnePlus 7 users.
  14. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 25, 2019 :
    Try Nacho Notch until it's back to normal. I don't know how it's done in Pixels on 10... But if Android 10 native support for the old ways is dropped you need 3rd party solutions.
    https://play.google.com/store/apps/details?id=com.xda.nachonotch
  15. CR7rokz
    CR7rokz , via OnePlus 7 , Dec 25, 2019 :
    can anyone plz confirm if pubg mobile game stays in memory bcoz in previous android 10 version on one plus 7 ...pubg mobile was not staying in memory and was reloading even if i minimised it once
  16. Pintu1989
    Eclair Dec 25, 2019
  17. Saibal1993
    Donut Dec 25, 2019
  18. Vignesh Smith
    Froyo Dec 25, 2019
    Vignesh Smith , Dec 25, 2019 :
    ya me also facing issue tht call haging
    arsalan.aarib likes this.
  19. Loki55
    Eclair Dec 25, 2019
  20. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 25, 2019 :
    Hmm... Read some on Pixel 3 XL with Android 10 hide notch solution. Seem it behaves the same as current solution here. So if that is the case, Google dropped the support for it in 10 and Oneplus needs to make a solution of their own.
    Will try to find more sources about it
