257
OxygenOS 10.0.3 [EU] and 10.3.0 [Non-EU] for the OnePlus 7 Pro and OnePlus 7
  1. anujay.aditya
    Gingerbread Dec 28, 2019
  2. anujay.aditya
    anujay.aditya , via OnePlus 7 , Dec 28, 2019 :
    everytime..or wait i can attach using different phone
  3. G_Swati_Dhanwate_uuNY
    Cupcake Dec 28, 2019
    G_Swati_Dhanwate_uuNY , Dec 28, 2019 :
    Instead of search option for app do it like side bar adcd.... like in contact so that touching that alphabet we can directly go to the app.
  4. pcpremengg
    Froyo Dec 28, 2019
    pcpremengg , Dec 28, 2019 :
    Whenever i turn on data in notification bar display like "Looking for incomplete download" in youtube app.
  5. anujay.aditya
  6. leshus
  7. leshus
    leshus , Dec 28, 2019 :
    Hi there,
    Yes, you've got a global firmware marked as GM21AA. AA stands for the global one, BA is for an EU version. Why do you want to change global firmware to EU? Just use global version. That one has a few pleasant perks. There are an equaliser and louder sound. No bloatware either.
  8. Z1558957527736
    Z1558957527736 , via OnePlus 7 Pro , Dec 28, 2019 :
    Hello! So I don't know if anyone is facing this problem or it's just me but after the update my battery is draining at an astonishing speed. Before the update at least the battery life was great for me but now it just drains really fast. Hopefully it will be fixed in the future.
  9. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 28, 2019 :
    Hard to see on the picture but low brightness has an side effect on amoled. Gray to gray (GTG) can get a pretty huge delay. Biggest effect can be seen with gray tones on black. You can even see the delay when a gray object moves on black background. Bigger delay the lower you go. It may be related to the screen limitations in low brightness that you have seen
  10. HRG_Henry
    Froyo Dec 28, 2019
    HRG_Henry , Dec 28, 2019 :
    I have this as well, but I'm on 10.0.2 still
  11. anujay.aditya
    are u able to check in yur device once?
  12. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 28, 2019 :
    Some claim using the correct firmware on your phone is important. The only side effects I can see is if the software and modem missmatch can cause issues. I don't know how the phone regulate the modem bands but since many has crossflashed with no issues I don't see a major problem with it.
  13. anujay.aditya
  14. HRG_Henry
    Froyo Dec 28, 2019
    Yes, low quality and sort of washed out colours.
    anujay.aditya likes this.
  15. anujay.aditya
  16. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 28, 2019 :
    I use a static picture on lockscreen. But if I use a live wallpaper I'm pretty sure the effects kick in more visible. Depending on when you look you can basically see an reduction of colors at some point both due to the dark brightness but also due to the lockscreen overlay.
  17. Aarav sheetal
    Donut Dec 28, 2019
  18. subiReddy
    subiReddy , via OnePlus 7 , Dec 28, 2019 :
    from last four months, I'm facing the battery drain issue don't know whether they fill fix these or not...
