257
OxygenOS 10.0.3 [EU] and 10.3.0 [Non-EU] for the OnePlus 7 Pro and OnePlus 7
  1. naushads
    Cupcake Dec 28, 2019
    naushads , via OnePlus 7 , Dec 28, 2019 :
    MAC was incorrectly entered into the router. But it was working on Android 9. So that means that upgrade to Android 10 changes the device MAC address?
  2. Aditya_Sharma@DE
    Eclair Dec 28, 2019
  3. E1577535523237
    E1577535523237 , via OnePlus 7 , Dec 28, 2019 :
    hhhh. after upgrade my Samsung level u won't be able to work on ONEPLUS7...
    it's get connected but didn't play anything.. just stuck , didn't play it..... need a fix... fast..
  4. rancid2202
    Najid kadakkadan likes this.
  5. RAHUL2VIJAY
    Froyo Dec 28, 2019
  6. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Dec 28, 2019 :
    Don't know when exactly. But I had a other wifi MAC at one point (proof in history in router... Wiped it some time ago though). Don't recall what series it had... Probably the new drivers that came with the randomizing support. Recall what series you had before? Any of the alternatives in the link below?
    https://www.cleancss.com/mac-lookup/98-09-CF
    As long as a device don't have a failsafe generic MAC it's all good. Was like that on a older device with Lineage OS once. Same MAC on every device [e]1f609[/e]
  7. Sahil_lihas
    Gingerbread Dec 28, 2019
    Sahil_lihas , via OnePlus 7 , Dec 28, 2019 :
    Bug Bug Bug
    Pics quality from back camera has increased and specialy nightscape has nailed it but
    Selfies and pics from front cam are very soft, faces are looks like beauty processed pic, there is very less details in front cam, it's look like a thumbnail,
    but believe me you guy have killed the GCAM MODS, the pics are better then Gcam from back camera, but still for front pic and selfies i use Gcam because there is very less details in front cam of OP7.
    overall this update is very good and has fixed some bugs, but new bug appeared like gestures bug i am not able to open menus by sliding from edge because of the gesture bug and also heating has been increased, yesterday mu device was locked but still is was heating, sometimes apps are taking lots of time to load.
    Lioli7k likes this.
  8. onefastfocus02 , via OnePlus 7 Pro , Dec 28, 2019 :
    does it improve if you turn off the phone Bluetooth and then turn it back on an let it reconnect? mine seems to improve ping that....is as if the Bluetooth went to sleep after not being used for awhile and then struggles to fully turn on and send all the signal once it connects to something. glad to see I'm not the only one.
  9. jatin0990
    Mordicus1973 likes this.
  10. Arun_Kashyap
    Arun_Kashyap , via OnePlus 7 , Dec 28, 2019 :
    Colours in the OnePlus stock camera are way too oversaturated under bright light and could be deceptive. GCam manages to capture them with almost correct colour reproduction. That's the only complaint I have with stock camera, otherwise it is great.
    Sahil_lihas likes this.
  11. G1559901600613 likes this.
  12. Jav P
    Jav P , Dec 28, 2019 :
    Without the full usage details it's impossible to know for sure what's using your battery. Also, you got 2h45min with 40%, which means that the full charge could average basically the 7 hours that you mentioned. Not sure what you mean.
  13. jeebwise
    jeebwise , Dec 28, 2019 :
    On top of the bluetooth issues I just had a complete system crash. Working on trying to downgrade my phone now. I don't care if I have to go back to kit kat or something:mad:
  14. Arun Easwaramurthy , via OnePlus 7 Pro Nebula Blue , Dec 28, 2019 :
    i meant is that without major use any heavy apps like games, i do not play any games and with only youtube, web browser it drains my battery heavily.
  15. Jav P
    You said that you used to get 7 hours SoT and the screenshot you posted shows basically that.
  16. M1569775468804
    Donut Dec 28, 2019
  17. G_Wajid_Shanediwan_TWvX
    Eclair Dec 28, 2019
    G_Wajid_Shanediwan_TWvX , Dec 28, 2019 :
    no broh the settings are same as it was on the previous update 10.0.2 . and on that build the battery wasn't draining as much as compared to this update.
  18. Lioli7k
    Donut Dec 28, 2019
    Lioli7k , via OnePlus 7 Pro , Dec 28, 2019 :
    I'm having that gesture bug as well after updating to 10.3.0AA.
  19. Jav P
    It's not a bug, the gesture to open the side menu has changed to adapt to the Android stock action. You need to hold the side edge for a second and then slide in.
  20. Lioli7k
    Donut Dec 28, 2019
    I know. But it's not as convenient as it were in versions before.
