259
OxygenOS 10.0.3 [EU] and 10.3.0 [Non-EU] for the OnePlus 7 Pro and OnePlus 7
  1. Tumio
    Gingerbread Jan 14, 2020
  2. SandeshChinchapur
    Jelly Bean Jan 14, 2020
    SandeshChinchapur , via OnePlus 7 , Jan 14, 2020 :
    This is OnePlus for you. Wait for the OnePlus 8 to launch, they'll leave you in tears.
  3. Kulwant_sin
    Eclair Jan 14, 2020
    Kulwant_sin , via OnePlus 7 Pro , Jan 14, 2020 :
    I'm already regretting it since 7T Pro launched. They have already moved on with it. I should understood this when they did the same thing to my oneplus 3T !
    BTW I've already had my screen changed for 15k since they did not roll out screen protection plan early. Perks of being loyal to this brand!!!
    Dirk66 likes this.
  4. Gertjan@
    Honeycomb Jan 14, 2020
    Gertjan@ , via OnePlus 7 Pro , Jan 14, 2020 :
    POE65
    Gertjan@
    When can we expect the new 10.0.4 update?
    Battery drainage 🤣.
    I think Januari..​
    Fortunately, I don't have high battery consumption [e]1f64f[/e]🤗
    I'm waiting for the new security patch in update 10.0.4
  5. HRG_Henry
    Froyo Jan 14, 2020
    HRG_Henry , Jan 14, 2020 :
    The shelf on the left side is constantly broken. Only restart helps for a day or two. Why even add this as a feature if it is not working...
    G_Nekozwartz_XD_YmBx likes this.
  6. SandeshChinchapur
    Lol, you shouldn't be falling in the same trap twice bro.
    Kulwant_sin likes this.
  7. JNiemi
    JNiemi , Jan 14, 2020 :
    Ei ainakaan tänään päivällä temppuillut yhtään, yhteys pysyi kokoajan päällä ja muodosti yhteyden jopa automaattisesti kun laittoi auton käyntiin.
    Itselläni on muokattu yhteys;
    AVRCP versio 1.6 (1.4 oletus)
    Siirto nopeus: 96 kHz
    Bittiä/näyte: 32
    Yht.Enim.määrä: 2 (oletus 5)
    Oletusasetuksilla toimii hyvin huonosti jos ollenkaan.
    Georgeoneplus7pro likes this.
  8. T1579001220643
    Cupcake Jan 14, 2020
    T1579001220643 , Jan 14, 2020 :
    onkos jossain linkkiä ohjeisiin yhteyksien muokkailuun. itellä ei oo tehty mupkkailuja ja todella raivostuttavaa kun näin kalliit vehkeet ei toimi...
  9. CobaltVO
    CobaltVO , via OnePlus 7 Pro , Jan 14, 2020 :
    Thanks for update, but after it I am facing one new problem. When you select swipe gestures to control the system (with the option of back button realized like swipe left or right), the area of working swipe was extended to the top right and left corners. Before this update this area was optimal: it was not covers top right and left corners, so it was allowing me open menus in the apps and - it is important - it allows to open drop-down Android menu (with quick setting like Wi-Fi) with the help of one finger with one motion. But at this update am facing the bug while opening drop-down menu: if you swipe with one finger from the top corner diagonally down then you will see that 2 actions are going: opening drop-down menu and showing back Oxygen mark (which indicates that back button will be pressed when you release the swipe). So, summary, what is going on: when I open drop-down menu with the help of one hand it is always close after I released finger from the screen. Could you please fix it?
    SpartanVissepo likes this.
  10. Kulwant_sin
    Eclair Jan 15, 2020
    Kulwant_sin , via OnePlus 7 Pro , Jan 15, 2020 :
    Thrice actually. It all started with oneplus one! The company valued the customers back then!
  11. Ven96
    Gingerbread Jan 15, 2020
    SpartanVissepo and JudePatrick like this.
  12. JNiemi
    Honeycomb Jan 15, 2020
    JNiemi , Jan 15, 2020 :
    Ei siihen ole ohjeita, eikä takuuta että toimisi yhtään sen paremmin kun vakionakaan. Mutta jos haluaa kokeilla muutoksia niin vaihtoehdot löytyvät Asetukset -> Järjestelmä -> Kehittäjäasetuksista
    Jos kehittäjäasetus valikko ei näy niin se pitää 'aktivoida'. Se tapahtuu Asetukset -> Tietoja puhelimesta kohdassa, naputa ohjelmistoversio numero ~10 kertaa niin puhelin kysyy suojakoodin ja ilmoittaa kehittäjä asetuksien olevan avattu.
    Jokainen tekee muutoksia em asetuksiin omalla vastuulla.
  13. akshay10dj
  14. POE65
  15. TommyHammy
    TommyHammy , Jan 15, 2020 :
    Every phone has standby drain. How do you think they monitor notifications, phone signal and wifi in the background?
    Q1548011232244 and Rishi_Pisces like this.
  16. F1578890633363
    Cupcake Jan 15, 2020
    SpartanVissepo and VIJAY216 like this.
  17. POE65
    POE65 , via OnePlus 7 , Jan 15, 2020 :
    Now OS 10.0.3 drain in night is 6%. In Pie 3%
  18. Harsha09
    Froyo Jan 15, 2020
    Harsha09 , via OnePlus 7 , Jan 15, 2020 :
    turn off everything and check it....
  19. B1571500439457
    B1571500439457 , Jan 15, 2020 :
    how do you delete cache after update? from reset factory?
  20. K1562610640724
    K1562610640724 , Jan 15, 2020 :
    turn off your phone and when your phone is shutdown, hold power button and volume down till you see the OP logo. the rest speaks for itself
