256
OxygenOS 10.0.3 [EU] and 10.3.0 [Non-EU] for the OnePlus 7 Pro and OnePlus 7
  1. Nic2112
    Ice Cream Sandwich Jan 17, 2020
    Nic2112 , Jan 17, 2020 :
    The irony of your comment is that you imply that "Chinese" means cheap... Where do you think they make the real OnePlus phones?
  2. Korok Hidup
    Gingerbread Jan 18, 2020
    Korok Hidup , via OnePlus 7 , Jan 18, 2020 :
    Jeez, how old are you?
    Luka_m125 likes this.
  3. everkurt
    Ven96 likes this.
  4. Z1571298953438
    Cupcake Jan 18, 2020
    Z1571298953438 , via OnePlus 7 Pro , Jan 18, 2020 :
    on my oneplus 7pro i have a problem with proximity sensor. when i am using laud speeker still my screen is off. unless other party will not disconnect the call i have to wait. some time it turn on automatically but not all the times. please oneplus team fix this issue in upcoming update thank you. other than that oneplus is king of Android no doubt [e]1f4aa[/e]
  5. T1579001220643
    T1579001220643 , Jan 18, 2020 :
    onko vinkkejä/ideaa miksei tallenna nuita muokattuja yhteysasetuksia? tarkemmin tuota khz ja bt/s?
  6. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Jan 18, 2020 :
    I think the default behavior is to start with the connected device default settings. If not it could cause issues with other devices not supporting the phone settings. If the headset has an app that can configure it you might have access to additional settings. My Sony headset has a nice app.
  7. T1579001220643
    my headset works fine (sennheiser) but i have problems connecting this phone with my 2011 E-class mercedes.. it used to work like it should but after some update it has never worked since. and older phones works with same devices and with my car but this doesn't.
  8. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Jan 18, 2020 :
    Is it possible to pair and connect? When connected or trying to connect you may want to send in a bug report via the feedback tool in the community app. They might be missing a compatible profile. Might have been a mistake during a recent rebase of Android 10 or something.
    Know the last functional version?
  9. T1579001220643
    can't say i do. never paid intrest when everything worked[e]1f601[/e] well the car says it's connected after veeery long authorisation. but the phone loses the connection in couple of seconds but the car still says it's connected.
  10. redbullman
    Froyo Jan 18, 2020
  11. Sandy9678
    Ice Cream Sandwich Jan 18, 2020
    Sandy9678 , via OnePlus 7 , Jan 18, 2020 :
    Can you share the change log?
  12. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Jan 18, 2020 :
    更新日志:
    系统
    • 优化系统后台管理机制
    • 改善部分应用黑/白屏的问题
    • 新增敏感权限使用强提醒
    • 提升系统稳定性并修复已知问题
    • 更新安卓安全补丁至2019.12
    小游戏
    • 新增小游戏,秒开游戏,点击即玩
    Translated into
    Update log:
    system
    • Optimize system background management mechanism
    • Improve the black / white screen of some applications
    • Add sensitive permissions to use strong reminders
    • Improve system stability and fix known issues
    • Update Android security patch to 2019.12
    Games
    • Added mini-games, start the game in seconds, and click to play
    Hydrogen updates does not always transfer well into Oxygen. Can be major differances.
    Sandy9678 likes this.
  13. E1579380950924
  14. madhavdhoot
    Donut Jan 19, 2020
    madhavdhoot , Jan 19, 2020 :
    The battery drains very quickly in Android 10.0.3 as compared to Android 9. can anyone please help me by suggesting what should I do.
    S.jayanth5445 likes this.
  15. Harsha09
    Donut Jan 19, 2020
  16. redbullman
    Froyo Jan 19, 2020
    redbullman , via OnePlus 7 , Jan 19, 2020 :
    hydrogen is much smoother than Oxygen, everyone should try it. noticeably faster.
  17. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Jan 19, 2020 :
    It has it's downsides too. For better and for worse it lacks GMS. Being without it may not always make stuff that easy. I would not recommend it though unless you live in China. And even then people choose to flash International sometimes.
    Unless I'm misstaken the privacy level is slightly different too
