257
OxygenOS 10.0.3 [EU] and 10.3.0 [Non-EU] for the OnePlus 7 Pro and OnePlus 7
  1. I1562869506998 , via OnePlus 7 Pro , Jan 24, 2020 :
    it's completely useless to talk about updates..
    their mainly focus in promotion of feature of upcoming products..
    I don't thing they are working on other previous phones or betterment for this..
  2. B1567776637880
    Froyo Jan 24, 2020
  3. Suraj gurav 007
    Ice Cream Sandwich Jan 24, 2020
  4. P1579875050340
    Cupcake Jan 24, 2020
    P1579875050340 , Jan 24, 2020 :
    Hello, I'm a first time user of OnePlus 7 Pro, my phone only vibrates when I'm called, I cand use this phone, when is the the actual usable release of Android version? The slider for volume is stuck, and it can't be unlocked. Notification doesn't work, batery is to hot, in just a few hours from buying only bugs.
  5. P1579875050340
    I factory rreset it 4 times, Is clear you post for the company, this is company fault for releasing softare without testinting basic functions!
    I1561546882857 likes this.
  6. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Jan 24, 2020 :
    Any screenshot of you sound settings?
    Some battery stats could be nice to see too
  7. B1567776637880
    Froyo Jan 24, 2020
    B1567776637880 , Jan 24, 2020 :
    sounds like your phone is defective. no amount of updates will fix that. all those things seem to work on my phone.
  8. idbl_fanatic1
    idbl_fanatic1 , Jan 24, 2020 :
    Ok, I can concur that this is correct, a factory reset, I have no issues at all either, and no, I do not work for OP
  9. B1567776637880
    Froyo Jan 24, 2020
    all the bugs I had went away for me after a reset. the only issue I have still is maps not working in Android auto
  10. idbl_fanatic1
    I don't have that issue
    Z1558843799122 likes this.
  11. B1567776637880
    Froyo Jan 24, 2020
  12. Janne72
    Donut Jan 24, 2020
    Janne72 , via OnePlus 7 Pro , Jan 24, 2020 :
    is it normal if you have to do factory reset that the phone works
  13. Janne72
    Donut Jan 24, 2020
    yeah, you are not the only one, mine too. i hope update soon
  14. Gungrave223
    Eclair Jan 24, 2020
    Gungrave223 , via OnePlus 7 Pro , Jan 24, 2020 :
    if only factory reset was enough to always unf* this phone...
    for what's it's worth...I think the really issue is with the base Android 10...followed by OnePlus just adding crap without working through the numerous bugs that's mainly a result of their crap memory management...
    best advice I can give is to do what I did...move to a AOSP rom...
    the 7 Pro is a great piece of hardware bogged down my crap software...but I still have hope which is why I check back every now and again...but might be time to give up hope...
    Luka_m125 and Federico Prencipe like this.
  15. B1567776637880
    Froyo Jan 24, 2020
    coming from a long time Android user and Rom flasher..... sometimes when you upgrade versions.... especially big updates like going up to a whole new version 9-10 things don't copy so smoothly. so things might not work properly. a factory reset cleans the slate. it's not too difficult to back up all your data so it's not so hard to restore your info
  16. Gordo96
    Eclair Jan 24, 2020
    Gordo96 , Jan 24, 2020 :
    Best advice is to stay on pie it works flawlessly, if the base 10 is screwed asop is based off that
    Ven96 likes this.
  17. Gungrave223
    Eclair Jan 24, 2020
    that's also true ... but then your security patch will be way behind...
    Talon1189 likes this.
  18. Gordo96
    Eclair Jan 24, 2020
    swings and roundabouts I would rather have a usable phone and out of date security.
  19. UnicornZ
    Honeycomb Jan 25, 2020
    UnicornZ , via OnePlus 7 Pro , Jan 25, 2020 :
    Thats a bad idea. Security patch updates are vital to protect the device.
