259
OxygenOS 10.0.3 [EU] and 10.3.0 [Non-EU] for the OnePlus 7 Pro and OnePlus 7
  1. Swejuggalo
    OnePlus 9 Series Expert Community Expert Feb 24, 2020
    Swejuggalo , via OnePlus 7 Pro , Feb 24, 2020 :
    You are free to use any theme you like. If you get a issue however changing to nuanced dark and change back to whatever you used before can sometimes fix theme related issues. Sometimes reboots seems to fix some color issues and stuff
    sarahmic likes this.
  2. sarahmic
    Honeycomb Feb 26, 2020
    sarahmic , Feb 26, 2020 :
    Is everyone happy with this update?
    Seems so as i can't see any new posts! :)
  3. ananda79
    Cupcake Feb 26, 2020
    ananda79 , Feb 26, 2020 :
    Hello everyone,
    I just check I can update my 7T to 10.3.1. But I am in France, and just understand my phone is in India version.
    I would like to update (upgrade) to the european version (just in case there is difference between 2 versions: for frequency management for example) but Oxygen OS forbid to install it.
    I downloaded the 10.0.7 and put it on /root. I startd the local update on the phone and it answer me I cannot donwgrade the version.... Yes 10.3.0 to 10.0.7 is a downgrade but it is not same version.
    Is there a possibility to do the task easily please?
  4. Swejuggalo
    OnePlus 9 Series Expert Community Expert Feb 26, 2020
    Swejuggalo , via OnePlus 7 Pro , Feb 26, 2020 :
    What hardware number does it have?
  5. ananda79
    It is a HD1900 model, my OS version is 10.3.0.HD65AA
  6. Swejuggalo
    ananda79
    It is a HD1900 model, my OS version is 10.3.0.HD65AA​
    Then it is a China import with Indian software.
    To change and/or upgrade you need 10.0.8 or 10.3.1. Since you want the EU version you need 10.0.8 not a older version.
    OnePlus[e]2122[/e]
    Everything OnePlus #NeverSettle
    Not endorsed by OnePlus
    https://t.me/OnePlus
    (open up with Telegram app)
    BTW you should be here writing about 7T.
    https://forums.oneplus.com/threads/...-10-3-1-in-india.1185592/page-7#post-21345918
  7. ananda79
    Thank you for your answer and sorry for the bad thread.
    IO think I can wait the official release on oneplus france website to download it?
  8. Swejuggalo
    It usually takes a long time before the update arrives on the homepage though (after global rollout)... But it gets there eventually. These files via Oxygen Updater and Telegram is figured out with the help of users getting real OTA files... I've never found that a file listed by Oxygen Updater or that Telegram channel has been different from the site... If it has been different it has been due to misstakes on the website and not the other way around [e]1f61c[/e]
    ananda79 likes this.
  9. ananda79
    ananda79 , via OnePlus 7T , Feb 26, 2020 :
    Swejuggalo
    It usually takes a long time before the updated arrives on the homepage though (after global rollout)... But it gets there eventually. These files via Oxygen Updater and Telegram is figured out with the help of users getting real OTA files... I've never found that a file listed by Oxygen Updater or that Telegram channel has been different from the site... If it has been different it has been due to misstakes on the website and not the other way around [e]1f61c[/e]​
    I just answer you from update oxygen OS.
    Oxygen updater is a great tool and help me. It can change from India version to Europe and a fresh install without any problem.
    Thank you for your support.
    Swejuggalo likes this.
  10. F_Juan_Tello_KhBy
    Cupcake Mar 23, 2020
    F_Juan_Tello_KhBy , Mar 23, 2020 :
    Nadie se ha dado cuenta que android 10 quita la opción a WHATSAPP de aviso de mensajes en ventana emergentes, por eso yo me quedo en android 9
  11. Jav P
    Honeycomb Mar 23, 2020
    Jav P , via OnePlus 7 , Mar 23, 2020 :
    Quieres decir esto?
    Funciona si lo activas en los ajustes, no dentro del app de Whatsapp.
  12. H1570196076554
    Donut Apr 10, 2020
    H1570196076554 , Apr 10, 2020 :
    hello my digital time on front of the display is not working properly some times it's stuck a lot and showing same time because of the I have to restart my device a lot of times can some one suggest me ant thing to do plzzzz...🥺🥺
  13. arun1092
    Gingerbread Apr 13, 2020
    arun1092 , via OnePlus 7 , Apr 13, 2020 :
    Hello, is this about the clock widget on home screen or digital clock in lock screen or clock in ambient display.. please specify, where you observe this.
  14. H1570196076554
    Donut Apr 13, 2020
    H1570196076554 , Apr 13, 2020 :
    No digital clock in status bar,at the top left
  15. arun1092
    Never read such an experience. Is it only in the status bar and no where else ?
  16. H1570196076554
    Donut Apr 13, 2020
    yess!!
  17. arun1092
    https://forums.oneplus.com/threads/clock-not-working-up-in-status-bar.506212/
    this is just one of the forums... looks like the issue happend to a few. in diffrent ways.
    try clearing app data of clock app.
    if not
    install google clock app and disable inbuilt clock app
    or else turn off automatice sync of time and date and correct it by yourself for once and then it will go smooth and correct.
    apparently i dont see an exact reason or solution to this issue jn any forum i just went through
  18. arun1092
    also keep only 1 app to deal with time and alarm.. remove everything else if you have any seperate alarm apps.
  19. H1570196076554
    Donut Apr 13, 2020
    thankyou soo kuch for this information [e]2665[/e]️[e]2665[/e]️
    arun1092 likes this.
  20. arun1092
    Do reply here if any of the steps in the forum, helped solve your issue.
    H1570196076554 likes this.
