259
OxygenOS 10.0.3 [EU] and 10.3.0 [Non-EU] for the OnePlus 7 Pro and OnePlus 7
  1. H1570196076554
    Donut Apr 15, 2020
    H1570196076554 , Apr 15, 2020 :
    also bro my oneokys 7 is hanging a lot suggest me something...
  2. arun1092
    Gingerbread Apr 15, 2020
    arun1092 , via OnePlus 7 , Apr 15, 2020 :
    Check Ram usage
    also list of installed apps..
    do check on apps that run in background and limit which is not needed.
    for eg a photo editor app might not need to run in background
    Also please tell an instatnce like opening a certain app causes hang
    do look into ganes that run in background and limit them
    permission for apps, eg a game dont need access to storage, microphone and camera
    hope this helps.
  3. H1570196076554
    Donut Apr 16, 2020
    arun1092 likes this.
  4. arun1092
    Gingerbread Apr 18, 2020
    arun1092 , via OnePlus 7 , Apr 18, 2020 :
    Bro,
    Ram Management is a new word i have seen in OnePlus and it felt awsome, I never felt any hang due to low memory.
    to tune it manually. (clearly this works for almost all android, different words on different phones)
    1. to keep an app always in memory, you can lock the app from the "recent open apps" screen. which will keep it in memory till you unlock it (look into three dots on right top of each app) this will have an impact on battery as well.
    2. To reduce ram usage, first step is to use minimal set of apps. like one app for music, one for video, one for photo edits etc. Its very hard for a normal user to find out which apps are always running in background. And please avoid apps for icons, wallpaper as these can be set individually by spending a few minutes.
    3. If you go to Apps Page in setting , for each app there is an option of Battery Management which is always set to "intelligent control". You can set it to "optimise" which will keep it out of memory while not using it. Also limit background data usage for apps that don't require it. Eg, Photo editing apps. Keeping background data on will trigger the app to stay in memory even if not used.
    please note for every manual tweak you do. There will be behavioral changes in respective app. so do keep a track of what you do and don't mess with system apps.
    My personal Suggestion: App like call blocker, antivirus are not needed if we keep a goid practice in what we browse and this we install apps. Avoid Sideloading, unless its absolutely necessary.
    Thank you
    Eduardo77 likes this.
  5. H1570196076554
    Donut Apr 18, 2020
    H1570196076554 , Apr 18, 2020 :
    thankyou bro for this much information ...I will follow as you say and see the changes in my phone [e]2665[/e]️[e]2665[/e]️
    Manindar Yadav and arun1092 like this.
  6. fahimbiya
    Eclair Jun 5, 2020
    TGP17 likes this.
  7. Artemus.
    Community Hero 2020 Jun 5, 2020
    Artemus. , Jun 5, 2020 :
    Oxygen Updater. You're welcome.
  8. Satrajit Chakraborty
    Honeycomb Jun 5, 2020
    Taras K. likes this.
  9. Artemus.
    Um. That's because you're in the wrong thread.
  10. X1564256788235
    Cupcake Jun 11, 2020
    U1563940528798 and ryl_ritesh like this.
  11. Artemus.
    Community Hero 2020 Jun 11, 2020
    Artemus. , Jun 11, 2020 :
    Can't. PUBG is a horribly-optimized game, expect high battery drainage.
    ryl_ritesh and akks like this.
  12. X1564256788235 and akks like this.
  13. akks
    KitKat Jun 11, 2020
    akks , Jun 11, 2020 :
    PubG kids always need help!! Battery, heat, lag, this that .. isn't there any gaming phone in the market?
  14. X1564256788235
    Cupcake Jun 12, 2020
    X1564256788235 , Jun 12, 2020 :
    I bought mobile for gaming experience. how can I stop playing.[e]1f602[/e]
  15. X1564256788235
    yes, please suggest me the graphics settings which will help us this battery draining and heat problems.
  16. AarishRaza
    Cupcake Jun 14, 2020
    AarishRaza , Jun 14, 2020 :
    akks
    PubG kids always need help!! Battery, heat, lag, this that .. isn't there any gaming phone in the market?​
    If the company is offering a top notch performance in speed and gaming so why not play games on the device ?
    I think Sd 855 should handle it with ease and there should be overheating or battery drain
    OnePlus should solve this
    And even gaming phones of that time offered the same specs so it made sense going for oxygenos
  17. Artemus.
    Community Hero 2020 Jun 14, 2020
    Artemus. , Jun 14, 2020 :
    It's not the phone, it's Tencent/Bluehole that's the problem. With Android, it's the developers that have to optimize their apps not the OEM. That's why there's so many fragments in the system.
    As for battery, high drainage is normal since it's using the battery to its highest. Same happens on a laptop.
  18. Vbj_OP_7
    Gingerbread Jun 15, 2020
    Vbj_OP_7 , via OnePlus 7 , Jun 15, 2020 :
    pubg is working great in my device....no lag no overheat...and the battery drains 20% if I play for an hour with extreme graphics(so 5 hrs SOT only with pubg will be insane if projected[e]1f633[/e][e]1f602[/e])...so I feel it's normal...
  19. burhan_bhol
    Froyo Jun 15, 2020
    burhan_bhol , Jun 15, 2020 :
    can u please tell me on whch graphics..?
  20. Vbj_OP_7
