248
OxygenOS 10.0.4 [EU and Global] and 10.3.1 [India] for the OnePlus 7 Pro and OnePlus 7
  1. f5oci3ty
    Eclair Feb 24, 2020
  2. Dirk66
    Gingerbread Feb 24, 2020
    Dirk66 , via OnePlus 7 Pro , Feb 24, 2020 :
    I wouldn't worry to much, for some all goes well and some have minor to annoying bugs or glitches. the criticism is mostly how they deal with updates and patches.
    so I would take the plunge and update. crossed fingers.
  3. Bernest44
    Honeycomb Feb 24, 2020
    Bernest44 , via OnePlus 7 Pro , Feb 24, 2020 :
    30 minutes north of Boston here!!
  4. V1rTu
  5. kmaier
    kmaier , via OnePlus 7 , Feb 24, 2020 :
    i have 10.3.1 in Europe, global version, and it works great. there are alot of complaints in this app, but my experience with two 6's in family and my 7 is great. really no problems at all
  6. J_Duece_81
  7. rahul_hr and Deactivated User like this.
  8. JmcRepair33
    Ice Cream Sandwich Feb 24, 2020
    JmcRepair33 , Feb 24, 2020 :
    question whichs is newer beta 9 or the new 10..0.4, i downloaded the 10.04 and has done it regularly through oygen updatre and then went to local install and doesn show up in the download. i even tried to copy it to my internal folder even though out of the million times i dine this xygen updater automatically downloaded it to the internal folder and just go into system update and choose Local Upgrade and choose the latest update but the 10.4 wont show up. im thinking beta 9 is newer then 10.0.4 ? why wouldnt it show up, any ideas on how to force it. i been doing this more many years. i know how to downoad and root and unlock bootloaders have a new phone every 5 months and always rooted. and tired of updating local updates and beta updates on my phone.. why can i find it even if i copy the zip to the local upgrade file and also in the insternal folder just i ncase. and doesnt show up in updates
  9. stevenrego
  10. Chhunhour_Kh
    Froyo Feb 24, 2020
    V1rTu likes this.
  11. kumarharsh8
    Gingerbread Feb 25, 2020
    kumarharsh8 , via OnePlus 7 Pro , Feb 25, 2020 :
    How is the charging holding up? For me on a it's gone bad, with bluetooth and mobile data on, I can hardly get 4-4.30 hours os SOT. Can someone suggest me anything or is it fine?
  12. Bernest44
    Honeycomb Feb 25, 2020
    Bernest44 , via OnePlus 7 Pro , Feb 25, 2020 :
    Not true. They are two totally different animals. One is Beta and the other Stable. Its all about taking risk. I was on Beta 9 and went to the new stable. I put Oxygen Updater on Full Update and it downloaded. Follow the directions and remember to do a back up. It wipes your data....some work to do, but so far this has been the best one. Only been a day...so I take it with a grain of salt. It solved one power up/restart issue I've had. No overheating or anything. All these issues people have. I've never had ANY battery issues.....and I know it's not all but some have done some things they can't recover from because they didn't do "something" correctly. Most crap I've done to my phone has ALWAYS been my own stupidity. I'm always learning.
    Deactivated User and Wrba like this.
  13. unnamed.brother
    Donut Feb 25, 2020
    unnamed.brother , Feb 25, 2020 :
    Exactly... I chose OP primarily because of OOS. Sure the hardware is great and comparatively cheaper, but for me, it's the software that makes a difference. You don't get to interact with the shiny glass back or camera modules everyday... You want stable software that is bug free, provides lasting battery performance, processes images nicely etc. OOS since Android 10 has completely failed at that.
    I feel like I am just complaining without bringing anything useful to the table but that's what it has come down to for me at this point. Sigh.
    Ake Winther likes this.
  14. Z1582596477094
    Cupcake Feb 25, 2020
    Z1582596477094 , Feb 25, 2020 :
    Hi, I just updated my phone to this version and there's a bug in the system. in the landscape mode I'm not able to swipe up to go home. I'm using the button less navigation mode that's NOT the iPhone copied Android 10 one
  15. Hardik47
    Eclair Feb 25, 2020
  16. Sahil_lihas
    Sahil_lihas , via OnePlus 7 , Feb 25, 2020 :
    u r right bro
    P1567915556992 likes this.
  17. E1562857001168
    Donut Feb 25, 2020
  18. mdhubail
    Eclair Feb 25, 2020
  19. Amits7251
    Froyo Feb 25, 2020
    Amits7251 , via OnePlus 7 , Feb 25, 2020 :
    wait its gonna get even worse with new updates, forget about getting the charging speed back , they won't even care
