245
OxygenOS 10.0.4 [EU and Global] and 10.3.1 [India] for the OnePlus 7 Pro and OnePlus 7
  1. G_ayush_aggarwal_TaGA , via OnePlus 7 Pro , Feb 26, 2020 :
    the update is good but with one lag that is when we opt for gesture where we go back either by swiping inwards from left or right, now after the update it automatically gets swiped. in other words when i am on a certain page without giving any back comand. to phone it takes me back to previous page.
    and even now while typing some letters are automatically typed by itself.
    rest the update is good
  2. G_Nicholas_Watson_DMuT
    Donut Feb 26, 2020
    G_Nicholas_Watson_DMuT , Feb 26, 2020 :
    I had that problem on previous update.
    Try clearing play store cache.,then
    re-boot. It worked for me anyway.
  3. Bernest44
    Gingerbread Feb 26, 2020
    Bernest44 , via OnePlus 7 Pro Mirror Gray , Feb 26, 2020 :
    You have something wrong. Make sure your VPN isnt pointed to some country where it's not compatible. I've had that happen. If it's pointed to Italy for instance...some apps won't function because I'm located here in the states. See the attached. I downloaded 10.3.1 and it's flawless. Netflix works fine.
  4. Antson Menachery , via OnePlus 7 , Feb 26, 2020 :
    I'm not using vpn at all! the app itself is not compatible as per Play Store
  5. Antson Menachery , via OnePlus 7 , Feb 26, 2020 :
    You are using OP7 Pro, mine is OP7
  6. Bernest44
    What I can tell you is that you should clear your Playstore cache....do NOT clear data. That just makes it start over and the phone will take time to adjust. Delete the Netflix app first.....then try a re-install.
  7. Antson Menachery , via OnePlus 7 , Feb 26, 2020 :
    I've tried that, not working, the app is pre-installed, cannot remove it. This issue started post updating to the latest version.
  8. Bernest44
  9. Bernest44
    Weird, maybe try downloading an apk file? Google for solutions?
    3
    Klikster•Jul 29, 2019
    I just read the same thing on this XDA Devs thread as well and grabbed the newest apk from apkmirror, it's working now! No idea why that happened though :p
    I HOPE THIS HELPS!!!
  10. Bernest44
  11. akks
    Jelly Bean Feb 26, 2020
    akks , Feb 26, 2020 :
    Recieved Google play system update with security patch level 1st February 2020 😎
    Swejuggalo likes this.
  12. O1574782788390
    Cupcake Feb 26, 2020
    O1574782788390 , Feb 26, 2020 :
    when I use any app like YouTube or any others app in landscape that time home swipe up is not working, so I will inform you pls solve that problem.
    Thank you OnePlus team [e]1f64f[/e]
  13. Cervantes
    Lollipop Moderator Feb 26, 2020
    Cervantes , Feb 26, 2020 :
    Hi
    the update thread is a question and comment thread
    Please, read the first post
    Use the search engine before opening a new thread
    Thread merged
    Alex_Cerv likes this.
  14. Luka_m125
    Froyo Feb 26, 2020
    Luka_m125 , via OnePlus 7 , Feb 26, 2020 :
    You have to double swipe home to work.
  15. Shahid Hakkim
    Deeppurple2525 likes this.
  16. akks
    No, wait for 11.5.11
    Shahid Hakkim likes this.
  17. Y1560088989718
  18. vladgaman
    vladgaman , via OnePlus 7 Pro , Feb 26, 2020 :
    I seem to be having this issue, not sure if related to this new version - when trying to search for a certain app, the written text appears to be black regardless of the general theme:
    jstiggie likes this.
