246
OxygenOS 10.0.4 [EU and Global] and 10.3.1 [India] for the OnePlus 7 Pro and OnePlus 7
  1. Masoom sharma
    Cupcake Feb 19, 2020
  2. DINESHKUMAR G B
  3. Garry garvit
    Eclair Feb 19, 2020
    Garry garvit , via OnePlus 7 , Feb 19, 2020 :
    even i didnt get that till now . dont know why oneplus always do stage roll out for bug fixes update
    Dirk66 likes this.
  4. iulisimo
    Honeycomb Feb 19, 2020
    iulisimo , via OnePlus 7 Pro , Feb 19, 2020 :
    akks
    Its insignificant update as you rightly said, so no reason for frustration​
    Like all OneMinus updates... insignificant. Only to shut up the crying mouths of the outraged unsatisfied customers.
  5. S1561224483655
  6. iulisimo
    Yes...even you....but who are you anyway?
  7. Chiragkhurana
    Eclair Feb 19, 2020
  8. Swejuggalo
    Lollipop Feb 19, 2020
    Georgeoneplus7pro likes this.
  9. DINESHKUMAR G B
  10. I1562869506998
    Gingerbread Feb 19, 2020
  11. Ankitoneplus7
  12. Polash13
    Polash13 , Feb 19, 2020 :
    I haven't received the update yet. But i have updated through oxygen updater. Will i get the next official update? or will i have to use oxygen updater for subsequent updates?
    TIA
  13. emmadirakesh
  14. Swejuggalo
    Swejuggalo , via OnePlus 7 Pro , Feb 19, 2020 :
    Is it charged to 100% during the measurement? Maybe it's optimizing. It's not strange to have some elevated processing some time if it's a recently updated device.
    I have not found a way to see CPU usage for every single app without using root... That would have been useful otherwise.
    You can however check what is normally draining the battery at the end of the da and before you normally charge. Elevated usage and charging both raises the temperature.
    Let it settle in and charge to 100% during a night or an hour or 2 extra after having reached 100% to let the system finish a background optimize.
    Georgeoneplus7pro and Alex_Cerv like this.
  15. Swejuggalo
    Ever since the first update of my 7 Pro there has never been an update that has been rolling out for everyone at the same time. It will come in time. Always staged rollout. Sometimes as far as for 2 weeks before global rollout. They release it that way to make sure nothing critical slipped by them and that they can stop the rollout if that is the case.
    Alex_Cerv likes this.
  16. heamanthstark
    Eclair Feb 19, 2020
    heamanthstark , via OnePlus 7 Pro , Feb 19, 2020 :
    OnePlus u made me sick because of this stage rollout this op7pro is my 1st OP device and I felt very happy about it cause I came to this phone from an 6k ordinary phone...... i I felt very happy for buying this phone but ur stage rollout is shit! please provide good and fast updates in future don't make me to think that why I bought this phone for 54k .. please!
  17. Kc21
    Kc21 , via OnePlus 7 , Feb 19, 2020 :
    download oxygen Updater from play store then go to settings and change the update method to incremental update,
    you will see the update
    vishal_breaksome likes this.
  18. Swejuggalo
    Using local upgrades does not affect future upgrades. Oxygen Updater will not do anything else than help with downloading a file directly from Oneplus servers.
    The files provided by the app is manually tested and verified by staff before adding them. It collects data from users that recive normal OTA files.
    Downloading (full 2GB) official updates from Oneplus servers is the same full files as Oxygen Updater offers (but updates the homepage much later - or atleast after global rollout)
