244
OxygenOS 10.0.4 [EU and Global] and 10.3.1 [India] for the OnePlus 7 Pro and OnePlus 7
  1. Tumio
    Gingerbread Feb 21, 2020
    Dirk66 likes this.
  2. Georgeoneplus7pro
    Jelly Bean Feb 21, 2020
    Georgeoneplus7pro , Feb 21, 2020 :
    Try to open the phone in safe mode and then test the battery.
  3. laikexpert
    Froyo Feb 21, 2020
  4. Tumio
    Tumio , via OnePlus 7 Pro , Feb 21, 2020 :
    THX
    I will try tomorrow if it doesn't exist what can be the problem?
  5. Georgeoneplus7pro
    If in safe mode the battery is ok, the fault is your mode of use and the applications installed by you. If the battery is consumed quickly in safe mode it must be replaced at a service center.
  6. laikexpert
    Froyo Feb 21, 2020
    laikexpert , Feb 21, 2020 :
    Please edit the title of this Thread.
    You should write like this:
    OxygenOS 10.0.4 (EU)
    OxygenOS10.3.1 (Global) and [India]
    for OnePlus 7 Pro and OnePlus 7
  7. Tumio
    the phone is clean, it only has whatsapp, banking app and that's it
    it is impossible to be such a problem
  8. Swejuggalo
    KitKat Feb 21, 2020
    Swejuggalo , via OnePlus 7 Pro , Feb 21, 2020 :
    Sound like VoLTE is not working or is it a completely down?
  9. Swejuggalo
    KitKat Feb 21, 2020
  10. Georgeoneplus7pro
    I have 1+7Pro12GB with 150app since it was launched and I have never had problems with the battery. From one update to another maybe I noticed sometimes small differences of 2-3%
    JNiemi and iulisimo like this.
  11. U1582326507908
    Cupcake Feb 21, 2020
  12. Kishorecena0196
    Cupcake Feb 22, 2020
  13. arun1092
    Froyo Feb 22, 2020
  14. Kishorecena0196
    Kishorecena0196 , via OnePlus 7 , Feb 22, 2020 :
    i have tried with 3 wifi networks... still it's not working... please help me on this
  15. arun1092
    Froyo Feb 22, 2020
    arun1092 , Feb 22, 2020 :
    remove sim, switch slots, insert another sim and re insert this again.. so that new network settings will be downloaded.
    if this wont work, reach out to jio customer care or its website to see list of devices that support VoWifi
  16. Kishorecena0196
    ok thanks for the tips
  17. arun1092
    Froyo Feb 22, 2020
    to add, i use airtel sim, and when connected to a wifi it takes a few moment for VoWifi to appear
  18. Kishorecena0196
    it's working fine with Airtel but its not working with jio
  19. WFMLANDGRAF
    WFMLANDGRAF , Feb 22, 2020 :
    Fala pessoal achei um bug nesta versão do op7p (10.3.1) quando o instalamos está versão, a barra de gestos não aparece, mesmo reiniciando o aparelho a barra não volta. A opção para arrumar isso é ir em gestos e depois nas configurações para ativar. E novamente quando ativar a mesma fica branca, depois de voltar ao menu a barra fica branca, só fica preta e branca quando vamos nas configurações.
    (Acabei de descobrir outro, quando você carrega o celular a barra simplesmente some)
    Alguém + com esse problema?????
  20. Rishi005
