49
OxygenOS 10.0.4 for OnePlus 7T Pro
  1. amitkarmoker
    Eclair Nov 19, 2019
  2. G_Faheem_Yazdani_(Feemy8 , via OnePlus 7T Pro , Nov 19, 2019 :
    @Manu J. since the update I have noticed a bug in the Download Manager.
    When I download/update apps from the Play Store, they show as installing in the notification bar at the top. However, the download progress bar does not show in the notification tray, nor do the updated apps at the bottom of the notification shade (see images below)
    Cleaning cache for the Download Manager sometimes fixes the problem. I am not sure if I should clean storage for Download Manager. I've also gone into Notification settings for Play Store and turned off then on all the notifications for updated apps. Also cleared cache and storage for Play Store, uninstalled updates, the downloaded most recent APK for the Play Store.
    I'm not sure what other troubleshooting steps to take.
    I wonder if anyone else has encountered this bug
  3. Funk Wizard
    Lollipop Moderator Nov 19, 2019
    Funk Wizard , Nov 19, 2019 :
    How or what app are you trying to set it with .. can you try with a different app or launcher and report, Thanks
  4. G_Faheem_Yazdani_(Feemy8 , via OnePlus 7T Pro , Nov 19, 2019 :
    On Recent Apps screen, if I have several apps open and scroll along, there is considerable stuttering in the animation. The more apps I have open, the worse it is. This should not be happening on the 7T Pro.
    A bug report has been submitted by another user but just wanted the community to be aware and report back if they notice this too
  5. G_Srinivas_N_uMmg
    Eclair Nov 19, 2019
    G_Srinivas_N_uMmg , via OnePlus 3T , Nov 19, 2019 :
    Is there any other difference other than regions between each 7T Pro models 1911, 1913 and 1913? Is there a different network supported bands for each models?
    Can someone provide me the information about supported network bands of Indian model 1911? The Amazon.in and OnePlus.in are having different details..
  6. Saruf_Ratul
    Froyo Nov 19, 2019
    Saruf_Ratul , via OnePlus 7T Pro , Nov 19, 2019 :
    WHIS IS HD1910 SIR ?
  7. Funk Wizard
    Funk Wizard , via OnePlus 7T Pro , Nov 19, 2019 :
    As far as I can remember for 7T Pro
    HD1910 is China version
    HD1911 is Indian version
    HD1913 European version
    HD1917 ROW/US
    Saruf_Ratul likes this.
  8. Saruf_Ratul
    Froyo Nov 19, 2019
    but I use oxygen os In my device is any problem
    when it unboxing in build in oxygen os.
  9. Funk Wizard
  10. Saruf_Ratul
    Froyo Nov 19, 2019
    Thank you for your attention [e]1f618[/e]
    never settle [e]2764[/e]️
    Funk Wizard likes this.
  11. Abhilash_PM
    Froyo Nov 19, 2019
    Abhilash_PM , Nov 19, 2019 :
    "Tap the screen to show" option Not working post update!
    "Tap the screen to show" option in Ambient display not working after the 10.0.4.HD01AA Update on my OnePlus 7T Pro McLaren Edition. I was using this feature until before the update and now irrespective of this option being enabled or disabled, the feature does not work. I am assuming that with all the standby optimization that came along this update, some code was left broken that was pertaining to this "Tap the screen to show" option.
    L1574254015210 likes this.
  12. W1574117858436
    Cupcake Nov 19, 2019
    W1574117858436 , Nov 19, 2019 :
    I have a One Plus 7T Pro Mclaren Edition. Just updated to 10.0.3 and 10.0.4 on the same day. Camera seems to be a major problem. Camera keeps freezing etc. esp on opening wide angle lens. Sometimes, it just shows a blank screen. Would anyone know why? Any resolution?
  13. Saruf_Ratul
    Froyo Nov 19, 2019
    Saruf_Ratul , Nov 19, 2019 :
    Wait for next update
  14. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Nov 19, 2019 :
    Have you tried to reset the camera app? If you wipe the app data it becomes reset with standard settings and everything. Or maybe just app cache
  15. antonyjen
    Jelly Bean Nov 19, 2019
  16. W1574117858436
    Yes. Did that. But still has the same issue. Is there an easy way to roll-back update?
  17. S1572808579771
  18. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Nov 19, 2019 :
    As far as I know there is no rollback file yet.
    A long shot perhaps... But checked the other camera components?
    If this isn't some kind of isolated incident of some kind we should have more users having it.
    Maybe someone here can verify than camera works perfectly fine or missbehaves exactly the same on McLaren version?
    BTW you got is as normal OTA?
  19. W1574117858436
  20. W1574117858436
    also, out of the box the camera did not have the option of wide angle and so on. it came with the 10.0.3 update. and that seems to be the issue.
    could it be a hardware issue with the wide angle camera? anyway to check that? if that's the case, will have to figure out a way to return the phone
