49
OxygenOS 10.0.4 for OnePlus 7T Pro
  1. rajarshi10
    Ice Cream Sandwich Nov 20, 2019
    rajarshi10 , Nov 20, 2019 :
    If I switch off WiFi then it doesn't connect to the mobile data automatically. I have to turn on and off the flight mode to enable data again.
    The auto brightness goes too dim even in a well lit environment and I have to manually fix it.
    Please fix these basic issues in a flagship device. These are unacceptable really.
    djtiestoja likes this.
  2. rajarshi10
    I don't think they will be able to fix this. This seems like a hardware limitation.
  3. T1574221265323
    Cupcake Nov 20, 2019
  4. T1574221265323
    getrealtunes likes this.
  5. FisherXDA
    Gingerbread Nov 20, 2019
    FisherXDA , via OnePlus 7T Pro Haze Blue , Nov 20, 2019 :
    Has anyones battery life gotten worse since update?
    I've left it a few days and my screen on time is consistent at about 3hrs where before I was getting 7hrs with moderate heavy use?
    thought this update was going to improve battery life not make it worse, even noticing I'm having to use charger multiple times a day to keep juiced up.
    cleaned cache, did a full wipe and still same issue. seems to be no app abnormally draining the battery. top usage is screen, then android system, then Google play services followed by Nova.
    it's really starting to annoy me it's also dropping significantly when not in use too, when in doze state.
    GAman_Verma and B1574273159502 like this.
  6. FisherXDA
    Your profile picture is hilarious and cute btw...is that your cat?
  7. Y.Singh
    Y.Singh , Nov 20, 2019 :
    I'm on the latest update for the 7t pro and when I charge my battery to 100 percent it drains quickly to 95 percent and then it just acts normal. I use the camera a lot about 1 to 2 hours a day. and my camera app takes up a lot of battery. but i've noticed that the camera app is using more of my battery in the background.
    I just about get 6 to 7 hours of screen on time with moderate use. my settings are full hd and 90hz with all the battery optimisation. I expect the battery life to get better for me as i've only had it for 2 days.
    also you can check what apps the phone puts to hibernate by going into developer setting and going into the standby apps and you can order it how you want. try that out. I thought my battery life was bad as I came from a 5 year old phone and thought battery life was good on newer phones but its not 2 day battery but I do get 6 hours minimum of sot.
    Also what you said about it draining when not doing anything. that happens to me it just loses like a couple percentage just sitting there after I have used it.
    FisherXDA likes this.
  8. DaftOldCat
    Donut Nov 21, 2019
    DaftOldCat , Nov 21, 2019 :
    Unfortunately not. It's Seymour from 4chan
  9. Amanvma
    Cupcake Nov 21, 2019
    Amanvma , Nov 21, 2019 :
    I am facing heating issue post update to 10.0.4 in my oneplus 7t pro.
    Anyone else facing the same
  10. rajarshi10 likes this.
  11. Amanvma
    Its not about playing yes during hardcore gaming it will heat i know but its started heating in normal usage also post update before that it was normal.
  12. Saruf_Ratul , via OnePlus 7T Pro Haze Blue , Nov 21, 2019 :
    I can't face that but hiting when playing games .
  13. N1574330972162
    Donut Nov 21, 2019
    N1574330972162 , Nov 21, 2019 :
    Does anyone know when 960fps will be added. Numerous media outlets have reported on this feature, and it was an important reason for my purchase. I just got the update, btw. So it's coming in hot.
  14. dor4859
    Donut Nov 21, 2019
    dor4859 , via OnePlus 7T Pro , Nov 21, 2019 :
    Hi there
    Mine is OP7T Pro McLaren version, after last update, the wifi connection is not stable as before. it can't connect or disconnect on and off. How we can solve it?
    Please assist.
    thanks.
  15. mafijoco
    mafijoco , Nov 21, 2019 :
    I have the exact same issue and its driving me crazy. Before the update we coulndt have ambient display(one tap) and double tap to show the Lockscreen. Now the only way to show lockscreen is to press the power button.
    @OnePlus , Please fix this issue or let me revert to 10.0.3.
  16. Neelavar Sumanth
    Gingerbread Nov 21, 2019
    Neelavar Sumanth , via OnePlus 7T Pro , Nov 21, 2019 :
    I've started to notice that Apps Hang after continuous usage of an hour or More ,you need to close the App , Forcestop it and then Open it again .
    This Happened to me on 2 Different Games today
    1.COD Mobile
    2.World of tanks Blitz
    and Would you believe if i say Instagram hanged too
    its like the Phone struggles to handle itself
    1. i don't have boat load of Apps
    2.That left out 1.9Gigs of RAM should be enough for surprise background processes if any decide to pop up
    3 And Android is supposed to used that much RAM ?
  17. Y.Singh
    Y.Singh , Nov 21, 2019 :
    Neelavar Sumanth
    1.COD Mobile
    ji View attachment 1186068
    I was looking at my ram one day and saw it reaching an average of five gigs. I only have 2 apps downloaded which is Instagram and Snapchat and was like ow. then I saw the Android system was averaging around 2 to 2.8gb usage
    what is happening.
    on top of that the oxygen launcher and other Android system things were using a lot of ram. also why does system take up nearly 30gb of storage. but my phone is very stable and fast.
  18. Nazimudheen
  19. radeatron
    Eclair Nov 22, 2019
    radeatron , via OnePlus 7T Pro , Nov 22, 2019 :
    Don't worry about RAM usage, RAM is automatically freed when you require more RAM.
    Free RAM is wasted RAM
    svvenn, deep0611 and B1574273159502 like this.
  20. rajan969
    Cupcake Nov 22, 2019
    rajan969 , Nov 22, 2019 :
    Hi! I updated my phone 3 days ago now today my phone got itself switched off or blackout while i was on a call
