49
OxygenOS 10.0.4 for OnePlus 7T Pro
  1. Funk Wizard
    Lollipop Moderator Nov 23, 2019
    Funk Wizard , Nov 23, 2019 :
    Try turning on auto switch to mobile data under wifi preferences. There is also force enable mobile data always active under developer options in case you want to try that setting
  2. rajarshi10
    Ice Cream Sandwich Nov 23, 2019
    rajarshi10 , Nov 23, 2019 :
    The force enable mode eats up battery like anything if you did not know.
  3. Funk Wizard
    Funk Wizard , via OnePlus 7T Pro , Nov 23, 2019 :
    I have all these on and still get through my day easily with 30-40% left. Sync, Location, Bluetooth all turned on all the time.
  4. rajarshi10
    Google it if you don't believe me. If you forcefully keep data on with WiFi, you lose considerable amount of battery. I don't know what your usage but since I turned it off I'm getting better battery life than before.
  5. svvenn
    svvenn , via OnePlus 7T Pro , Nov 23, 2019 :
    I would rather do research on "what is ram and how it works". Why are you making useless conclusions on something you're not familiar with?
  6. Y.Singh
    Gingerbread Nov 23, 2019
    Y.Singh , Nov 23, 2019 :
    I was just surprised why it was taking up so much ram my older phones such as the so never took this much ram. also system did not take up 28gb on the so but on the OnePlus it does. I just want an explanation why it takes so much.
  7. stuartblofeld
    Eclair Nov 23, 2019
    stuartblofeld , via OnePlus 7T Pro , Nov 23, 2019 :
    yes!! scrolling issues are really frustrating. it's not smooth and fast. it's slow, unresponsive and jerky. not impressed at all at the moment with 7TPro. I upgraded from my OnePlus3 and that was way way smoother! go figure.
    rajarshi10 likes this.
  8. stuartblofeld
    Eclair Nov 23, 2019
    I've never seen mine light up either! didn't even realise it existed until I saw it posted elsewhere. haven't yet found that setting to switch it on (if there is one). guessing there probably is but we'll buried in config settings....
  9. RaBjo
    Froyo Nov 23, 2019
    RaBjo , via OnePlus 7T Pro , Nov 23, 2019 :
    You are in the wrong forum, alas.
    This is the 7T Pro forum.
    Not the 7 Pro.
    The 7T Pro is a newer model, the "T" is a small upgrade.
  10. Nazimudheen
    Cupcake Nov 23, 2019
    Nazimudheen , Nov 23, 2019 :
    Go to settings > Display > Ambient Display > Horizon Light
    stuartblofeld and I1574515554410 like this.
  11. andrea.soc
    andrea.soc , Nov 23, 2019 :
    hi
    im newbie in Oneplus, now i have an Oneplus 7tpro and Is fantastic but i dont known how to for add an screen in the left of home screens or on right.
    thanks
    Andrea
  12. stuartblofeld
    Eclair Nov 23, 2019
  13. Nazimudheen
    mine too..it was working at the first but not now....
  14. Y.Singh
    hello mate my scrolling is perfectly fine and smooth on my 7t pro. my battery life was decr when I started using it 1 week ago which was around 6 hours of sot but now it's amazing now I get at least 7 and a half with mostly 8 to 9 with moderate usage of YouTube and social media apps with camera used for half an hour.
  15. srasun143
    Eclair Nov 24, 2019
  16. Y1572711441835
    Cupcake Nov 24, 2019
    Y1572711441835 , Nov 24, 2019 :
    the automobile Bluetooth connectivity is still the same even after updating....
    the audio being played on phone either online or through media player music., it is getting stuck/skip ....unoptimized...
    plz check it again
  17. Saruf_Ratul , via OnePlus 7T Pro Haze Blue , Nov 24, 2019 :
    Awesome [e]1f44d[/e]
    B1574273159502 likes this.
  18. krishnansasi
    Froyo Nov 25, 2019
    krishnansasi , via OnePlus 7T Pro , Nov 25, 2019 :
    There are issues in this update
    1. Do not disturb mode doesn't really work. Sounds notifications come through and horizon light also comes up. Checked all possible settings. Have to use toggle switch to make it silent.
    2. Android Auto keeps crashing after the update.
    3. OTPs from banks don't come through. Same with Uber app. That has been the issue since day 1, even before this update
    Battery backup is better after the update and the phone has stopped restarting when using heavy apps.
    Do fix these issues. I keep going back to my 2017 Huawei Mate 10 Pro and that 2 yr old phone is just as good as this one in most areas and way better in some, like stability, ram management, battery backup, customization etc.
  19. RomanD76
    Donut Nov 25, 2019
    RomanD76 , Nov 25, 2019 :
    since the update to 10.0.4 I notice motion sickness when on 90hz mode... haven't had this on 10.0.3....had to switch to 60hz mode :-(
    anyone else with this problem?
  20. avinash_verma
    Gingerbread Nov 26, 2019
