49
OxygenOS 10.0.4 for OnePlus 7T Pro
  1. avinash_verma
    Gingerbread Nov 26, 2019
  2. ONEplus42069
    Cupcake Nov 26, 2019
  3. Rahul7tPro
    Donut Nov 26, 2019
  4. rajarshi10
    Ice Cream Sandwich Nov 26, 2019
    rajarshi10 , Nov 26, 2019 :
    Please introduce always on display in the next update if possible. That feature is requested so much in the One Plus forums as well as Reddit.
  5. T1574795958755
  6. Y.Singh
    Gingerbread Nov 27, 2019
    Y.Singh , Nov 27, 2019 :
    I'm back again. so a new bug I have found is when you go into the app drawer and you search for something the text appears black so you cannot see it. if you use a lighter background you can see that the text is in a very dark grey.
    we need a fix for this. please see the attached pictures below. Ty.
  7. MR95
    Cupcake Nov 27, 2019
    N1569435403430 likes this.
  8. E1569413431866
    Donut Nov 27, 2019
    E1569413431866 , Nov 27, 2019 :
    Not true - even stable software updates are staged. Nobody in the industry ever rolled out a massive update to millions of users at once, whatever the industry (smartphones, cars, gaming, whatever).
  9. ktk89
    ktk89 , Nov 27, 2019 :
    When dual VOLTE is enabled facing lot of network issues...mobile data is taking time to turn on showing "!"Symbol.
    If dual VOLTE is disabled...mobile network is working flawless..also more signal I'm getting and instant mobile data turn on without ! Symbol.
  10. getrealtunes
    Froyo Nov 27, 2019
    Roby Mathew and B1574273159502 like this.
  11. Y.Singh
    I can confirm that I am NOT facing any of these issues. this could be as I'm using a case (the one that came in the box).
    getrealtunes likes this.
  12. getrealtunes
    Froyo Nov 27, 2019
    getrealtunes , via OnePlus 7T Pro , Nov 27, 2019 :
    I'm rocking a Case too, it only happens every now and then, I'm thinking it's either software or the screen protector.
    B1574273159502 likes this.
  13. Y.Singh
    sometimes my hand is just touching the screen so it could be due to that. also is your scrolling issue like it scrolls slowly and like it's elastic? if so then I recommend cleaning the screen and make sure no hands are touching your screen.
  14. getrealtunes
    Froyo Nov 27, 2019
    it's like it refuses to scroll as fast and as fluid as it usually does, it will stutter and sometimes jump around. It's strange
  15. Y.Singh
    the scrolling issue could be down to the software as when using the guestures to open up recent apps sometimes you have to swipe and hold but sometimes it doesn't work so you swipe Futher and further until it actually happens. that can be annoying af.
  16. getrealtunes
    Froyo Nov 27, 2019
    I'm thinking that it might just be some bugs, like the ones that plagued the OP7 Pro when it first came out, being that the software is still a bit buggy at the moment
  17. Y.Singh
    mine only stutters when the page hasn't fully loaded. it's probably due to unoptimsed pages or apps. also the scrolling speed is super fast on the OnePlus so maybe the thing doesn't load quick enough for it to scroll.
  18. Y.Singh
    agreed I have found many bugs such as when searching for a app in the app drawer you cannot see the font as it's very dark. lots of little bugs but I have posted in the community app so hopefully they will read it and make a fix.
