49
OxygenOS 10.0.4 for OnePlus 7T Pro
  1. G_Kang_Wei_Kang_tDpF
    Cupcake Dec 8, 2019
  2. G_alok_alokkumarkalal_JG
    Donut Dec 8, 2019
    W1544798359461 and donaldvc like this.
  3. D1569554543845
    Cupcake Dec 8, 2019
    D1569554543845 , Dec 8, 2019 :
    there is a issue that suddenly pop up of Google assistant,and it disturb a lot in day to day exp. please fix this issue
  4. F1557991933350
    Cupcake Dec 8, 2019
    F1557991933350 , Dec 8, 2019 :
    Hello, I got my 7T Pro since 2 weeks now, and the camera is blurry. It's so hard to take a sharp photo.. Can anyone help me? Or is it a known bug? I'm on 10.0.4
    Best regards,
    Nico
    chinna2ali likes this.
  5. B1571062806517
    Eclair Dec 9, 2019
    B1571062806517 , Dec 9, 2019 :
    WhatsApp given update for tht check latest update of whatsapp log.
  6. Emmanuel Velez
    Cupcake Dec 9, 2019
  7. alaarishi87
    Cupcake Dec 9, 2019
  8. AlizainAkber
    Gingerbread Dec 9, 2019
    AlizainAkber , Dec 9, 2019 :
    yes im facing it too
  9. rajat04099
    Gingerbread Dec 10, 2019
    rajat04099 , via OnePlus 7T Pro , Dec 10, 2019 :
    Always clean your camera with a soft piece of cloth before using it for amazing shoots.
  10. C1575560527260
    Eclair Dec 10, 2019
    C1575560527260 , Dec 10, 2019 :
    hi there ! please explain is always on display active. if yes please let me know how to activate it
  11. stetre76
    Honeycomb Dec 11, 2019
    stetre76 , Dec 11, 2019 :
    @C1575560527260
    There is no "always on display" as you know it from ex the Pixe series.
    There is an ambient dsplay which activates when you lift the phone or tap the screen (depending on you settings), but the screen will go dark again after a couple of seconds.
    OnePlus has mentioned that it might be releasing an "Always on Display" setting with one of the next updates, but....who knows.
  12. mystifiedx
    Cupcake Dec 11, 2019
  13. W1544798359461
    W1544798359461 , Dec 11, 2019 :
    Still on October security update and the phone is buggy as hell. So glad no one listened when I said "get a OnePlus".
    Should be on December by now surely. I thought I'd be getting pixel like security updates at least.
    Not good enough OnePlus.
  14. stetre76
    Sorry, but if you want to get Pixel-like security updates, then you shouldhave bought a pixel...which is far more expensive, has a mediocre battery life and a display that's imho just a bit below the 7T Pro
    And - a security patch won't necessarily solve any bugs your device shows, it simply closes security issues that come up with Android
    For addressing any bugs you'd need a software update from OnePlus...
  15. W1544798359461
    I get this in WhatsApp and Instagram.
    This phone is currently useless for WhatsApp sharing, posting on Instagram.
    As a side to everyone experiencing lag and stutter, of you have the factory screen protector, it's static building up causing It.
    My phone was laggy as hell til I removed the factory protector.
  16. W1544798359461
    HAHA far more expensive than pixel? You can get them for less than OnePlus now.
    Pixel 3 and 3 XL have roughly the same features and are a LOT less
    OnePlus and the users have always talked up fast updates due to nearly stock great software and it's a lie.
    If you don't have anything useful to say then don't say anything.
  17. W1544798359461
    And as for the OnePlus display.. it is good at best. Pixel 3 XL has as good a screen and you can use a screen protector.
    Put the OnePlus next to an S10 which costs the same and the OnePlus screen is average.
  18. stetre76
    So why did you buy a OnePlus then, when you are sooooo unhappy?
    I am coming from Pixel phones and to be honest...I haven't had so many positiv wow-moments with any phone as with the 7T Pro McLaren right now.
    And comparing the 7T Pro to the Pixel 3/XL is...well, just a bit off, as the Pixel 3 was released in 2018, the 7T Pro in October 2019 - see the difference?
    If you want to compare the phones, compare it with the Pixel 4/XL - and there's quite a difference in the price tag (at least here in Europe)
    But who knows, maybe I am just lucky, because I have no problems with Instagram, no problems with sending/sharing photos right out of WhatsApp, neither any lagging issues or problems with the screen (using a Whitestone Dome Glass) - oh happy me
    Huigiebaby likes this.
  19. ngydat
    Lollipop Dec 11, 2019
    ngydat , Dec 11, 2019 :
    You say that but even if it had the December security patch, you wouldn't see the difference in terms of the user experience.
    Huigiebaby and stetre76 like this.
  20. rajat04099
    Gingerbread Dec 11, 2019
    rajat04099 , via OnePlus 7T Pro , Dec 11, 2019 :
    Agreed. But, we would have enhanced security.
