49
OxygenOS 10.0.4 for OnePlus 7T Pro
  1. DaniAndTheWeb
    Eclair Dec 15, 2019
  2. inamatus
    Froyo Dec 16, 2019
    inamatus , Dec 16, 2019 :
    Oneplus should receive Suck Award for this year. Extremely horrible development. There're many bugs that can't fix and abandon flaship user. Oneplus will drag to hell soon. I'm very disappoint with this brand. This is my first and last phone with Oneplus brand.
  3. Nobu01
    Gingerbread Dec 16, 2019
    Nobu01 , via OnePlus 7T Pro , Dec 16, 2019 :
    All you have to do is set up your company and show us that you do better than Oneplus !
    Personally i come from the Samsung Galaxy S10+ and above i have the security patches of December but i preferred by far to use my Oneplus 7T Pro...
    If you want quick updates then go buy a Google Pixel instead of sending us your free and unfounded bitterness.
    Have a good day.
  4. Zither74
    Donut Dec 16, 2019
    Zither74 , Dec 16, 2019 :
    So the 10.0.3 update had security patch 2019/11.
    And the 10.0.4 update has security patch 2019/10?
  5. Swejuggalo
    OnePlus 9 Series Expert Community Expert Dec 16, 2019
  6. Mazharapps , via OnePlus 7T Pro McLaren Edition , Dec 16, 2019 :
    hi
    I'm using OnePlus 7T Pro McLaren Edition, HD1910, OOS 10.0.4.HD01AA
    if I download is for OnePlus 7T Pro, shall I get the McLaren theme there? I'm scared about losing McLaren look from the os.
  7. C1575560527260
    Eclair Dec 16, 2019
    C1575560527260 , Dec 16, 2019 :
    hi I was trying to set up face unlock, but it's asking device pin when I enter the pin it's struck there not moving forward. pls help
  8. Abhilash_PM
    Froyo Dec 16, 2019
    Abhilash_PM , Dec 16, 2019 :
    The OP7T Pro and the OP7T Pro McLaren Edition have the same software package. The McLaren theme is automatically installed if you have the McLaren Edition device. If you don't have the McLaren device, then this theme will not be installed. So don't worry; go ahead and install the update. Don't forget to wipe the cache from the bootloader once you update (tutorial here) to avoid minor issues.
  9. Abhilash_PM
    Froyo Dec 16, 2019
    Try removing all security lock features such as pin, fingerprint, pattern etc. and re-configure.
    C1575560527260 likes this.
  10. Mazharapps , via OnePlus 7T Pro McLaren Edition , Dec 16, 2019 :
    but there is no ROM for HD1910.
    What I can do now?
  11. Mazharapps , via OnePlus 7T Pro McLaren Edition , Dec 16, 2019 :
    I've another question: how to make a clean flash in OnePlus 7t Pro or OnePlus devices? is there any tutorial or thread related? if yes, pls share
    thanks in advance
  12. Abhilash_PM
    Froyo Dec 16, 2019
    I believe HD1910 model code is China Region model. You can download the rom from Chinese page: https://www.oneplus.com/cn/support/softwareupgrade/details?code=PM1574149493992
    Please note: that is is a full rom package and not the incremental one so it will be huge (about 3.5GB). Also this will kinda do a clean install.
    You may use Google translate to understand whats written ;)
  13. Swejuggalo
  14. Abhilash_PM
    Froyo Dec 16, 2019
    Yes usually you'd find the procedure on the devices's official software download page. For e.g. https://www.oneplus.in/support/softwareupgrade/details?code=PM1574162297465
    Scroll down to find the title : 'How to upgrade system?'
    If you want the cleanest re-flash, do a factory reset after reflashing the full rom. (Warning! all of your data would be wiped, so please backup all your data before performing this). After that when you set it up, don't re-sync AppData from cloud, instead start fresh.
  15. infinity.erdem
    Cupcake Dec 20, 2019
    infinity.erdem , Dec 20, 2019 :
    Literally bruh OnePlus has confusing us a lot with the different build versions for the same versions and also is very abrupt in rolling out updates...
