49
OxygenOS 10.0.4 for OnePlus 7T Pro
  1. Swejuggalo
    Community Bug Hunter Nov 16, 2019
    Swejuggalo , via OnePlus 7 Pro Mirror Gray , Nov 16, 2019 :
    Let it settle in for a few days. The battery may need to charge over night a few times to allow background optimizing too. You could check for any battery hogs in battery stats. The system automatically tries to learn your usage pattern and will deside what apps to optimize or don't optimize. Standard is intelligent control but you can manually change it for some apps.
    You can also try things like having ram boost off. Some 7 series users had better battery then. Would not surprise me if it is the same for 7T series.
    Think the latest update had some battery fixes too. If you haven't got it yet you probably will soon enough.
    Deactivated User and Gazouille like this.
  2. Villanr8265
    Cupcake Nov 16, 2019
  3. Gazouille
    Gingerbread Nov 16, 2019
    Gazouille , Nov 16, 2019 :
    With Oxygen Updater app.
    But only for international version for now... Not EU.
    Don't now how many difference could be but...
  4. amitkarmoker
    Eclair Nov 16, 2019
  5. amitkarmoker
    Eclair Nov 16, 2019
  6. Gazouille
    With chrome?
    Which content?
  7. Kethrildur likes this.
  8. amitkarmoker
    Eclair Nov 16, 2019
  9. amitkarmoker
    Eclair Nov 16, 2019
  10. charmingash
    Honeycomb Nov 16, 2019
    charmingash , via OnePlus 7 , Nov 16, 2019 :
    7t pro pic lacks sharpness but better dynamic range tho.
  11. Swejuggalo
    You can always manually adjust some apps to your liking. If timely notifications does not matter for an app you could select to optimize it (limiting its background behavior).
    Use nuanced dark (dark mode) for less drain from screen. Check if ram boost gives your specific usage any advantage or higher drain. Disable apps you don't need or want.
    Depending on the level you want to tweak your phone you can google "adb disable app" to disable stuff you are normally not allowed to disable.
    If you go down the adb route you can install stuff like BetterBatteryStats to monitor wakelocks and get more detailed battery stats, ignore some wakelocks that annoys you, "supercharge" Doze with tools like Naptime, manually start the background optimizing function...
  12. G_Bob_Wagemans_gTvm , via OnePlus 7T Pro , Nov 16, 2019 :
    it works! did it myself
  13. jayantrajpandey
  14. DUBBLE35 , via OnePlus 7T Pro Haze Blue , Nov 16, 2019 :
    Okay but the 10.0.4 is released
    When can I download it ?
  15. danvxz
    danvxz , via OnePlus 7T Pro , Nov 16, 2019 :
    you know you just described a beta right?
    software developers releases stable update to everyone at the same time, including Samsung and apple.
    that's why they have betas, to do exactly as you said.
    but this is supposed to be a stable,
  16. Last edited: Nov 16, 2019
