124
OxygenOS 10.0.4 for the OnePlus 7T and OxygenOS 10.0.3 for OnePlus 7T Pro
  1. RaraBunny
    Donut Oct 21, 2019
  2. RaraBunny
    Donut Oct 21, 2019
    RaraBunny , via OnePlus 7T , Oct 21, 2019 :
    I've already checked that as well. No luck so far.
  3. salil_009
    Cupcake Oct 21, 2019
    salil_009 , via OnePlus 7T , Oct 21, 2019 :
    Macro is hardware based, not software so 6t cannot get it
  4. khalid123 , via OnePlus 7T Glacier Blue , Oct 21, 2019 :
    I'm not sure if this will help, but try this:
    Go to Phone
    Dial *#*#4636#*#*
    Select Phone Information and Post the screenshot
  5. G_Fauzaan_Ahamed
    Froyo Oct 21, 2019
  6. RaraBunny
    Donut Oct 21, 2019
  7. sskamesh , via OnePlus 7T Frosted Silver , Oct 21, 2019 :
    Get a duplicate SIM from official Airtel store. It should come up after 24 hours. Tweet Airtel saying that you're not getting VoLTE too. I did the same and got it within 24 hours.
  8. skgoyal2190
    Froyo Oct 21, 2019
    skgoyal2190 , Oct 21, 2019 :
    are you sure battery drain resolves?
    observe it for 2 more days and pls do let us know the results.. as I do have the battery drain issues and that's the reason I rolled back to 10.0.1
    aif battery drain fixes with 10.0.4, then only I will update it further.
  9. khalid123 , via OnePlus 7T Glacier Blue , Oct 21, 2019 :
    Well that checks out perfectly fine.
    Do you live in an urban area with good coverage? Might be a problem with the network itself because VoLTE with airtel is working perfectly fine on my device and most others.
    One last question though: Do you get an icon "HD" while calling other airtel numbers with VoLTE devices? Check the image below for reference.
  10. ARAGONDA BALAJI , via OnePlus 7T Frosted Silver , Oct 21, 2019 :
    it takes time for first time voltee enable Airtel i have faced the same problem after two days voltee enabled for Airtel it's not device fault it's Airtel networks issue
  11. khalid123 , via OnePlus 7T Glacier Blue , Oct 21, 2019 :
    Yes it does. Give it some time. I've personally observed 7-8 Hours of SOT today while mostly streaming media on Netflix and VLC, browsing 2-3 social media apps, checking mail frequently and Viewing documents. Not a gamer at all so these stats are for no gaming.
  12. skgoyal2190
    Froyo Oct 21, 2019
    okay, M also not a gamer but if you are saying 7-8 hrs of SOT after update, that's really great.. they definately did something it means.. lets observe this for couple of days too. Thanks for the update.
  13. Aviroop96
    Aviroop96 , via OnePlus 7T , Oct 21, 2019 :
    Even if you still have the gestures, they would soon be removed.
    Google made it mandatory for device manufacturers to use their gestures. They put a stop on third party device manufacturer's gestures from android 10.
  14. vinit299
  15. Y1512301148021
  16. saranshvaid
    Froyo Oct 21, 2019
  17. Swole Is The Goal
    Swole Is The Goal , Oct 21, 2019 :
    I did this and it says it's version 10.0.3 but with the changelog of 10.0.4. Same for you?
