123
OxygenOS 10.0.4 for the OnePlus 7T and OxygenOS 10.0.3 for OnePlus 7T Pro
  1. Kethrildur likes this.
  2. pkair
    Honeycomb Oct 22, 2019
    pkair , Oct 22, 2019 :
    I didn't even get the first android 10 update on my 7 Pro...
  3. anirbanmazumdar
    Cupcake Oct 22, 2019
  4. Manish_Saha
    Eclair Oct 22, 2019
  5. B1571410930463
    B1571410930463 , via OnePlus 7T , Oct 22, 2019 :
    fix that dolby sound issue! seems like sound coming from a tin box! In headphones the voice is not detailed!
    vocals are way muddy and muffled. The other problem is unavailability of a portrait mode that has options. The camera UI needs improvement. The 2 things, sound and Camera are aweful.
  6. G_Yogi_R
  7. Y1571782053105
    Y1571782053105 , Oct 22, 2019 :
    Guys, my keyboard has get slower than stock verssion. Maybe is the vibration... I dont know. Tapping quickly was better on the stock verssion.
    PLEASE, FIX IT!
  8. ngydat
    KitKat Oct 22, 2019
    ngydat , Oct 22, 2019 :
    What keyboard do you use ?
  9. Y1571782053105
    Cupcake Oct 23, 2019
    Y1571782053105 , Oct 23, 2019 :
    ngydat
    GBoard, stock keyboard... I tried tipping on my friend Oneplus 7t, with Oxygen 10.0.3, and I have also experienced the same. I'm talking about milliseconds of delay, when tipping fast.
    it will be a matter of improving it with future updates
  10. ngydat
    KitKat Oct 23, 2019
    ngydat , Oct 23, 2019 :
    Guess I'll see in the following days then since I've just bought my One Plus 7T today. The only thing I've noticed so far is the absence of notifications for Gmail
  11. Y1571782053105
    ngydat
    Guess I'll see in the following days then since I've just bought my One Plus 7T today. The only thing I've noticed so far is the absence of notifications for Gmail​
    In the version that came standard, the keyboard was very good. after updating it, I have noticed more laggy.. On which Oxygen version are you?
    For notifications, go to settings/apps and notifications/show all apps/GMail/notifications... There you might find a solution for your issue
  12. ngydat
    KitKat Oct 23, 2019
    That's the thing though : gmail isn't listed in the apps (I mean in the battery optimisation)
  13. Y1571782053105
    ngydat
    That's the thing though : gmail isn't listed in the apps​
    Try to uninstall, and installing It again. Then, enter to the recovery mode and wipe caché.
  14. ngydat
    KitKat Oct 23, 2019
    The latest one : 10.0.4
  15. Y1571782053105
  16. AstroBoy89
    Eclair Oct 23, 2019
    AstroBoy89 , Oct 23, 2019 :
    I didn't see anything in the forums and there's definitely complaints in the play store, but has anyone figured out a way to UPDATE GOOGLE SYSTEM WEBVIEW? You hit update, it loads, then just syas update again, but the stop button shows like it's actually still updating, but it isn't. Restarting the phone, clearing the cache and data for play service, the play store, and the webview does nothing.
  17. AstroBoy89
    Eclair Oct 23, 2019
    Well I just figured it out. Cleared only the cache for system webview, force stopped play store and cleared all data, force stopped play services and cleared data, restarted phone. Boom problem solved.
  18. Dueyy
    Dueyy , Oct 23, 2019 :
    Will OxygenOS ever have an accent color hex value option for Android 10 like how it was on Android 9 for OxygenOS.
