124
OxygenOS 10.0.4 for the OnePlus 7T and OxygenOS 10.0.3 for OnePlus 7T Pro
  1. Tomy159
    Froyo Nov 3, 2019
    Tomy159 , via OnePlus 7T Pro , Nov 3, 2019 :
    It's just me or is really battery poor with this new update or all phone? Have it around 10 days first 3 days no problem with AOD app have it 11 hours on display after update and reset all phone no AOD app not have more then 6 hours.
  2. maortrol
    Honeycomb Nov 3, 2019
  3. I1570521819255
    Cupcake Nov 3, 2019
  4. bentx
    Cupcake Nov 3, 2019
  5. Sugirtha Sudharsan Surya , via OnePlus 7T , Nov 3, 2019 :
    Lots of Off Screen Function issue
    1. Double Tap Sometimes working and many times not working.
    2. Adaptive Brightness issue not yet resolved
    3.sensor not working properly morely irresponsive.
    4. Battery drain more faster even at mobile unused
    krishna2581997 and gthing2264 like this.
  6. ayushgupta64
    Donut Nov 3, 2019
  7. Bijayagiri007
    Cupcake Nov 3, 2019
    Bijayagiri007 , Nov 3, 2019 :
    Double tap doesn't work properly..
    What has to be done ?
    krishna2581997 likes this.
  8. ToggoSan
    Cupcake Nov 3, 2019
  9. quickstang
    Froyo Nov 3, 2019
    quickstang , via OnePlus 7T , Nov 3, 2019 :
    I'm on the latest and have it. Definitely need an update. Mine is hit and miss when it happens. Getting frustrating considering I just got the phone Friday.
  10. S1572654987397
    Cupcake Nov 4, 2019
    S1572654987397 , via OnePlus 7T , Nov 4, 2019 :
    hola buenas, soy nuevo con el móvil que tengo, pero con los juegos a veces se quedan pillados no sé porque será eso?? alguien podría decirme algo al respecto
  11. T1565253301586
    Donut Nov 4, 2019
  12. maortrol
    Honeycomb Nov 4, 2019
  13. Nebste76 , via OnePlus 7T Frosted Silver , Nov 4, 2019 :
    dear OP
    few things which I have noticed on my OP7T. a couple of apps like Cloud Print, Samsung Accessories Service and Watch Active Plugin are visible in app drawer among other apps. Mentioned apps are sort of system apps and wasn't visible before in drawer (OP6 i had before). if you choose to click on those app nothing happened, but I'm redirected to app info page with option to disable or force stop app. second thing is if you set different name and app icon than stock one, and make this app locked in app locker, each time you lunch this app on the lock screen is visible stock icon rather than the one you custom choose. the name is change upon your decision.
    please fix those bugs. tnx
  14. Sugirtha Sudharsan Surya , via OnePlus 7T , Nov 4, 2019 :
    Yes I too can able same in oP7t not in op6t
  15. krishna2581997 likes this.
  16. rchile
    Eclair Nov 4, 2019
    rchile , via OnePlus 7T , Nov 4, 2019 :
    I can see some glitches in YouTube videos while playing in dark room at night , please fix this with update it really annoying to see good display like this at night time.
  17. Jamun
    Cupcake Nov 4, 2019
    Jamun , Nov 4, 2019 :
    Hey guys,
    As i have gifted myself an 1+7 t for myself for the first time i am facing a bug issue relating to locking system ...The device gets unlocked only to swipe without any thumb scan or any pass (pin)even though it is applied in security and lock settings.kindly suggest what is the settings to be made on the device or do we have any solution for this.
  18. KusumaKumar , via OnePlus 7T Glacier Blue , Nov 5, 2019 :
    turn off on body direction
