124
OxygenOS 10.0.4 for the OnePlus 7T and OxygenOS 10.0.3 for OnePlus 7T Pro
  1. pcprash
    Donut Nov 6, 2019
    pcprash , Nov 6, 2019 :
    kindly do something for battery draining issue. ONEPLUS 7T has a very bad experience of battery draining. within 12hrs of normal useage of ONEPLUS 7T it drains from 100% to 15%. this is disappointing and sad. ONEPLUS 6TPRO MCLAREN was much far more superior in battery than ONEPLUS7T.
    Y1572177533166 likes this.
  2. Varaprasad G16
    Cupcake Nov 6, 2019
    Varaprasad G16 , Nov 6, 2019 :
    So much Irritating Ambient display...Some times its not working...very bad experience in OnePlus 7T Plzzz fix it with nxt update...
    plzz provide atleast always on in display finger print...with ambient display....
  3. L1571875118597
    Cupcake Nov 6, 2019
    L1571875118597 , Nov 6, 2019 :
    To 10.0.0.4? No, still at 3.
  4. BabusankarMenon
    Cupcake Nov 6, 2019
  5. Gaurav Goenka
    Donut Nov 6, 2019
    Gaurav Goenka , via OnePlus 7T , Nov 6, 2019 :
    Facing what's app freezing problem.
    Tried everything clear cache, re-install WA app.
    And last install in my old op 3 in that same WA ac working fine.
    But again again when I re-install in op7t same freezing problem and 'app not responding' error comes continously.
    Need urgent solution for this
    krishna2581997 likes this.
  6. ngydat
    KitKat Nov 6, 2019
    ngydat , Nov 6, 2019 :
    Indeed the battery consumption seems to have decreased
  7. Bunny05
    Cupcake Nov 6, 2019
  8. ngydat
    KitKat Nov 6, 2019
  9. ChristianHeilos
    Gingerbread Nov 6, 2019
    ChristianHeilos , via OnePlus 7T Pro , Nov 6, 2019 :
    just a quick question. is there anyway to turn of the haptic feedback when "sliding up" to view the recent apps (or when accessing the hidden apps space)? I've googled and couldn't find a solution that turns of the haptic feedback for those two interactions. i've turned off all haptic feedback / vibrations (also in the google keyboard). thanks for any suggestions.
    p.s. I'm running a OP7T Pro on stable build 10.0.0.3
    JaviAC likes this.
  10. ngydat
    KitKat Nov 6, 2019
    there isn't
    ChristianHeilos likes this.
  11. Z1571895240005
    Cupcake Nov 6, 2019
  12. asdankit
    Eclair Nov 6, 2019
  13. Z1571895240005
    Cupcake Nov 6, 2019
  14. X1567084170296
    Eclair Nov 6, 2019
    X1567084170296 , Nov 6, 2019 :
    please, update my oneplus 7 pro, i have a lot of bugs and glitches, low performance... these appeared after oxygen os 10.0.1 udate. please resolve it, i am waiting for a month...
  15. C1572733407037
    Cupcake Nov 7, 2019
    C1572733407037 , Nov 7, 2019 :
    I play on call of duty and the game got stuck ... I had oneplus 3t and the game was not stuck like here .. Maybe a problem is in android 10?
  16. Shahreyar95
    Honeycomb Nov 7, 2019
    Shahreyar95 , Nov 7, 2019 :
    My OnePlus 7T pro's WiFi keeps getting disconnected and connects again. Due to which when I play Pubg or Call Of Duty the game gets stuck and I get logged out.
    And the other issue is regarding my 4g, when I switch my WiFi off, the 4g doesn't switch on even when the mobile data is enabled. I have to restart the mobile to switch it on. And sometimes when it's on I get an exclamation mark and have to restart again.
    The contacts app displays blurry pictures of my contacts even when I choose high definition pictures.
    Any resolution for these issues?
    I can't find the software to download for the OnePlus 7T pro on the support page.
    Oxygen OS: 10.0.3.HD01AA
  17. yashgaur2112
    Donut Nov 7, 2019
    yashgaur2112 , Nov 7, 2019 :
    What the hell...dial pad not working properly, because of which not able to make calls. Please fix it ASAP One Plus team this is not good for your brand..what you guys are doing..are you with settling down with what you have currently or you are still on Never Settle?
    H1571583686685 likes this.
