251
OxygenOS 10.0.5 [EU and Global] and 10.3.2 [India] for the OnePlus 7 Pro and OnePlus 7
  1. Action_Pretty
    Honeycomb Apr 14, 2020
    Action_Pretty , Apr 14, 2020 :
    Petko_Antonov
    because you are not among the chosen of OnePlus to receive it.
    mine and other trash OnePlus 7 mid-range devices are not worthy
    I wonder what will EU authorities will fine OnePlus once I file in a complain about their discrimination...ops randomness .​
    Petko...i thought russian ppl were smart, pls don't change my opinion...i.m sure oneplus has better things to do than to be racist...if you are so desperate to get the update, why don.t you use oxygen updater?
    martinparker28 likes this.
  2. charmingash
    charmingash , via OnePlus 7 , Apr 14, 2020 :
    nope op8 cis gonna be oppo customized 48mp 1/1.43 size one
  3. BrunoRodrigues15
    Froyo Apr 14, 2020
    BrunoRodrigues15 , Apr 14, 2020 :
    Still is not that difficult to port improvements and features since the sensor remains the same despite sensor size
  4. I1586860677569
    Cupcake Apr 14, 2020
  5. Swejuggalo
    OnePlus 9 Series Expert Community Expert Apr 14, 2020
    Swejuggalo , via OnePlus 7 Pro , Apr 14, 2020 :
    Most that I read pointed to same 48MP on main but also wide angle.... But not the same sensor. Just same megapixel
  6. BrunoRodrigues15
    Froyo Apr 14, 2020
  7. Jav P
    Jav P , via OnePlus 7 , Apr 14, 2020 :
    Most problems with the slider are caused by dirt accumulated in there, switch it to the Ring position and with a needle try to remove it. It will amaze you how dirty it can get. It happened to me.
  8. Jav P
    You can change that feature in settings - display - screen saver.
  9. Swejuggalo
  10. 7ajaj
  11. Darsh93
    Gingerbread Apr 14, 2020
    Darsh93 , via OnePlus 7 , Apr 14, 2020 :
    I don't care if people are going to come up and say, 'its a staged rollout'.. 'it will take time'. screw that, it's been 2 weeks now and yet this shit update is nowhere to be seen
    chiragbhoj likes this.
  12. Action_Pretty
    quit bitching and use oxygen updater.
    kmaier likes this.
  13. Swejuggalo
    7 International and especially the 7 Pro EU started later then the other 2. Maybe the since the rollout of those two started later they might be also finishing the rollout at a later time
    Darsh93 likes this.
  14. Darsh93
    naa.. I'm not going to.. it's stupid to make people wait 2 weeks for an incremental update.. if they have the audacity to flaunt and announce and update then they should deliver too.. and mind you, this is not the first time it's happening
  15. Darsh93
    thanks mate.. I appreciate the information you gave.
  16. Gertjan@
    G_El_Hadj_Chitou_zagD likes this.
  17. ravi3234
  18. Iain webster
    Froyo Apr 14, 2020
    Iain webster , Apr 14, 2020 :
    I agree, why should you have to use non oneplus apps to update? That is just a crap method. This is not good. I wont be buying another like i i have already stated.
  19. Dhru1
    Dhru1 , Apr 14, 2020 :
    Hey i haven't get update in my one plus 7. The update is 10.3.2 when will it come.
