251
OxygenOS 10.0.5 [EU and Global] and 10.3.2 [India] for the OnePlus 7 Pro and OnePlus 7
  1. G_prasanna_surya , via OnePlus 7 Pro , Apr 21, 2020 :
    actually they mention to factory reset the mobile that also won't help na, they ask to downgrade the software,I try to downgrade the software but it's showing downgrade is not possible nu
  2. Yogesh Pardhi
    Eclair Apr 21, 2020
    Yogesh Pardhi , Apr 21, 2020 :
    I got the update on my onplus7 almost 3 days ago.....but now the mobile is heating a lot.....while charging it gets worst.....while normal use still it heats.....i tried factory rest and still the problem is same.....The onplus needs to solve this problem...
  3. himanshusaxena0001
    Gingerbread Apr 21, 2020
    patelyash2015 and Aleemsiddiq like this.
  4. usayad
    Cupcake Apr 21, 2020
    usayad , Apr 21, 2020 :
    After this update I'm facing some issues.
    1. My auto screen lock does not work. I have set it for 15sec, but it's not working, hence tried changing to less or more time, still does not work.
    2. After I force lock, if any notification receives, the display gets ON till the time I won't force lock again using power button.
    3. Got heat issue, when I charge even for 10-15 mins which previous I never encountered. Even when my Alarm rings for 8-10 mins it got heated up. before this updates alarm rights for even 1 hour also, but it never heard up.
    This is just 2 days of observation. is any1 else facing similar issues....???
  5. I_am_ironman
    I_am_ironman , Apr 21, 2020 :
    everything works fine for me expect charging takes bit longer,face unlock is slow rest is best OnePlus 7 at 10.3.2
  6. I_am_ironman
    roll back to pie
    Venkatesh_thota likes this.
  7. V1587460852133
  8. V1587460852133
    V1587460852133 , Apr 21, 2020 :
    太费电了,太费电了,太费电了[e]1f44e[/e][e]1f44e[/e][e]1f44e[/e][e]1f44e[/e]🏿[e]1f44e[/e]🏿[e]1f44e[/e]🏿[e]1f44e[/e]🏽[e]1f44e[/e]🏽[e]1f44e[/e]🏽[e]1f44e[/e]🏼[e]1f44e[/e]🏼[e]1f44e[/e]🏼[e]1f44e[/e]🏻[e]1f44e[/e]🏻[e]1f44e[/e]🏻
  9. Venkatesh_thota
    Froyo Apr 21, 2020
    Venkatesh_thota , via OnePlus 7 , Apr 21, 2020 :
    facing same problem.....heats a lot while charging
    Aleemsiddiq likes this.
  10. Venkatesh_thota
    Froyo Apr 21, 2020
    guys after update I am facing some issue
    phone heats up alot while charging
    and also there are framedrops while playing pubg...
    is there anyway to revert back to previous version?
    pcpremengg and Aleemsiddiq like this.
  11. Action_Pretty
    Honeycomb Apr 21, 2020
    Action_Pretty , Apr 21, 2020 :
    simple, just charge without playing or doing anything to your phone.
  12. C1563444973666
    Donut Apr 21, 2020
    C1563444973666 , via OnePlus 7 , Apr 21, 2020 :
    yes it is correct , after updating you will receive further updates. i prefer to stay with 9.5.8 as i had problems in 10.0.3 and rolled back to 9.5.8. Good luck.
  13. Action_Pretty
    I think that everybody that complains about battery are using warp charge alongside playing heavy games like pubg or call of duty.
    At the moment I am in Vietnam and with all the humidity here (although I have the AC turned on) I still get max of 38 degrees while warp charging and left alone. If I play some video on youtube while using bluetooth headsets, the battery goes to max 42 degrees. I think these are normal ranges of temperature. Btw, if you don't have to charge your phone quickly, just use any other cable, your phone will not heat up and your battery will thank you in the long run.
  14. L1577114305379
    L1577114305379 , via OnePlus 7 Pro , Apr 21, 2020 :
    open Google app from menu....click on more at the right hand corner down below....then click on settings then Google assistant...then click on assistant...scroll down to the end and under devices click on phone.. and scroll to find ambient mode
  15. santoshKanuri
    Eclair Apr 21, 2020
  16. Poussin16
    Poussin16 , via OnePlus 7 , Apr 21, 2020 :
    hi all ,
    I have this is version since available.
    battery is draining fast.
    it still long time this issue.
    but now,I think it'd critical compared to previous version.
    I will check to reset all phone and make battery calibration.
    otherwise,I think the best way to solve all issues met on my phone is to quit one plus.
  17. usayad
    how to roll back? just to previous version 10.3.1?. mine is oneplus 7 pro
  18. Venom07
    Eclair Apr 21, 2020
    Venom07 , via OnePlus 7 Pro , Apr 21, 2020 :
    Download that ROM from the OnePlus update site and upgrade it locally.
    the file size is about 2GB
  19. Siddiq.aleem
    Siddiq.aleem , via OnePlus 7 , Apr 21, 2020 :
    hello team
    greetings for the day
    plz note that after update I have observed that my one plus 7 device is heating a lot and self restarting and battery drain ing.
    plz note I am facing this on basic usage .
    plz help me to resolve this ...
    moreover I would request you to add dual audio support via bluetooth headset
    thanks
    will be waiting to the solution .....
    abheyarora likes this.
  20. I_am_ironman
    bro just factory reset mann this update is the best mann 10.3.2 best battery backup i have ever seen better than pie even in this heavy use still at 40%
