251
OxygenOS 10.0.5 [EU and Global] and 10.3.2 [India] for the OnePlus 7 Pro and OnePlus 7
  1. Venkatesh_thota
    Froyo Apr 21, 2020
  2. Venkatesh_thota
    Froyo Apr 21, 2020
  3. BetiK
    Ice Cream Sandwich Apr 21, 2020
    BetiK , via OnePlus 7 Pro , Apr 21, 2020 :
    I'm sorry. If it happens to my phone I would get lost, because I don't know how to do those procedures and worst in Brazil we don't have any assistance or even a OnePlus store. Hope some day after this terrible crisis they will consider our market. Anyway I think you should publish your complains in the feedback space so they will make corrections needed. Good luck.
    Ven96 likes this.
  4. Action_Pretty
    Honeycomb Apr 21, 2020
    Action_Pretty , Apr 21, 2020 :
    so what is the problem? you had 2 hours for 25%, that means more or less 8 hours of SOT. Perfectly normal.
  5. I_am_ironman
    Gingerbread Apr 21, 2020
    I_am_ironman , Apr 21, 2020 :
    there is an option in system in the settings
    Venkatesh_thota likes this.
  6. Z1575053654743
    Cupcake Apr 21, 2020
  7. Action_Pretty
  8. Z1575053654743
    Z1575053654743 , Apr 21, 2020 :
    No, i charged it and went to sleep. No wifi or 4g. nothing was running in the background.
  9. Racer@007 , via OnePlus 7 Mirror Gray , Apr 21, 2020 :
    yes. they have sent me some operation tutorial to perform on my phone. I will try it then afterwords I will give feedback
  10. Racer@007 , via OnePlus 7 Mirror Gray , Apr 21, 2020 :
    if the fix doesn't come, I will definitely take it to the service centre
  11. F_Castro_EICP , via OnePlus 7 Pro Nebula Blue , Apr 21, 2020 :
    Since the last update (10.0.5.GM21BA) by OTA for my OnePlus 7 Pro, if i have VoLTE activated, then every time someone calls me it shows as unknown caller.
    If i deactivate VoLTE, it doesn't happen.
    I already found more users complaining about it.
    If it wasn't enough that almost 1 year and several complaints from numerous users, you keep not updating the OnePlus Logkit for us to have the VoLTE option, forcing us to install one shared on XDA, what used to work before this update.
    Now, even with your "staged rollout update policy" there's this extremely annoying bug!
    It's my first OnePlus and beside the phone itself, it is turning to be a real disappointment!
  12. G1587481762633
  13. Racer@007 , via OnePlus 7 Mirror Gray , Apr 21, 2020 :
    I started performing set of operation given by OnePlus by dialing *#800# but after stage 5 I got stuck and my screen just went white. I had to reboot. I have sent this issue again to OnePlus hope they will reply soon.
  14. BetiK
    Good luck.
  15. G_prasanna_surya , via OnePlus 7 Pro , Apr 21, 2020 :
    May I know what's ur temporary while charging
  16. I_am_ironman
    G_prasanna_surya likes this.
