251
OxygenOS 10.0.5 [EU and Global] and 10.3.2 [India] for the OnePlus 7 Pro and OnePlus 7
  1. abheyarora
    Froyo Apr 21, 2020
    abheyarora , via OnePlus 7 , Apr 21, 2020 :
    same problem within me device randomly restarting i rolled back to pie.
  2. Action_Pretty
    Honeycomb Apr 22, 2020
    Action_Pretty , Apr 22, 2020 :
    3 days after installing the update, the battery seems to have been improved by considerable ammount.
    Went from 7.5-8 hours to 8 and a half solid; 90hz and QHD+ on.
  3. G_Patil_Nagarjuna_JDfm , via OnePlus 7 , Apr 22, 2020 :
    After my update to 10.3.2 one of my sim is diactivacted
    I asked one plus care they told
    it is issue with the simcard
    all I know is after update only this thing happened
    before it is working fine
  4. D1562310094157
    Cupcake Apr 22, 2020
    D1562310094157 , Apr 22, 2020 :
    I have found a system bug. you can no longer adjust screen brightness in landscape mode.
    Please fix this ASAP.
  5. Widoon
  6. AbhijnanGhosh
    Donut Apr 22, 2020
    Ciprian Flower likes this.
  7. Action_Pretty
    you mean like this? works fine...in what application are you trying?
  8. Action_Pretty
    have you tried activating from the settings? and also, have you tried if it works in another phone?
  9. Action_Pretty
    then it's the simcard that's broken.
  10. Wrba
    Gingerbread Apr 22, 2020
    Wrba , Apr 22, 2020 :
    im currently using 9.5.5 and i want to update so badly to 10,
    and I'm reading this forum constantly from the first update to 10.... and there are problems all the time, i know that people who are posting are posting because they have a problem otherwise they wouldn't post.
    So is there anyone that is satisfied with android 10
    and that would recommend me to update?
    thank you
  11. G_Patil_Nagarjuna_JDfm , via OnePlus 7 , Apr 22, 2020 :
    how it will be broken after update yaar
    before is is working fine
    you can check some other persons also facing the issue
  12. Action_Pretty
    Wrba
    thank you​
    a lot of ppl posted that all is fine, just read the posts ..you can always go back if you encounter issues.
    Pawcio62432 and Wrba like this.
  13. Action_Pretty
    you can check some other persons also facing the issue​
    i can only see you having this issue, so if the sim is not working after in any phone, just get another sim it's that simple and probably only solve. Your issue is probably hardware and not software.
  14. sam311
    Ice Cream Sandwich Apr 22, 2020
  15. patelyash2015
    Froyo Apr 22, 2020
    Tumio and Shalin235 like this.
  16. patelyash2015 likes this.
  17. L1587556537126
  18. Rajevikas
  19. W1587097952078
