251
OxygenOS 10.0.5 [EU and Global] and 10.3.2 [India] for the OnePlus 7 Pro and OnePlus 7
  1. H@ppyj@ri
    Donut May 26, 2020
    H@ppyj@ri , via OnePlus 7 , May 26, 2020 :
    what about one plus 7 ?
  2. H@ppyj@ri
    Donut May 26, 2020
    Swejuggalo
    Welcome. I guess that would be the 10 upgrade. Depening on what region you would get 10.0.2/3 first and then upgrade either 10.0.5 or 10.3.2. With an upcomming update in the near days. The first day you may experiance some extra drain until the system settles in and learns you useage pattern and optimizes itself.
    If you ask me. Upgrade and report all the issues you get. Avoiding upgrades is no good long term solution.
    Inside the community app you will see the feedback section. Use that to report and give suggestions.
    Enjoy your phone.
    when ? what about one plus 7 ???
  3. Adi_2019
    Ice Cream Sandwich May 26, 2020
    Adi_2019 , via OnePlus 7 , May 26, 2020 :
    I am not sure about all manufacturers but I guess only iPhone, Pixel and OnePlus devices are getting long term support for 3 or more years.
  4. Adi_2019
    Nobody knows the exact date but one can anticipate an update in one week based on the trend.
    I am guessing latest commotion over photochrome camera on the OnePlus 8 Pro has also kept OnePlus busy.
  5. Davidjana
    Cupcake May 26, 2020
  6. Artemus.
    Community Hero 2020 May 26, 2020
    Artemus. , May 26, 2020 :
    The 7 Pro has had A10 for awhile now.
  7. Sahil_lihas
    Honeycomb May 26, 2020
    Sahil_lihas , via OnePlus 7 Mirror Blue , May 26, 2020 :
    T1568968698893
    I'm Charging With Warp Charge 30 But It Showing Only Charging. I'm Facing This Problem since Oxygen Is 10.0.3 to 10.0.5. It Pissing Me Up. Fix It In New Update Or Else I'm Buying Another Brand Phone. There Is Many Bug In Oxygen Is 10.0.5 like Heating issue, While Calling It Doesn't Recognize Face Which Later Show Black Background Plz Fix It...
    what do u want except written charging
    there is written 42% Charging
  8. sarahmic
    sarahmic , May 26, 2020 :
    I have the exact same problem! .
    wolf4477 likes this.
  9. Swejuggalo
    OnePlus 9 Series Expert Community Expert May 26, 2020
    Swejuggalo , via OnePlus 7 Pro , May 26, 2020 :
    I based that on the normal release schedule. 1 update per 1-2 months. Since the last one have an announment post the end of the month soon 2 months back... [e]1f609[/e] Unless some issues causing delays in internal testing it should be soon.
    Artemus. likes this.
  10. Imrankhan6055
    Gingerbread May 27, 2020
    Imrankhan6055 , via OnePlus 7 Pro , May 27, 2020 :
    Try roll back to previous version. If that didn't help. You usb cable is faulty. I face the same issue and i visited service center and they offered me a brand new cable.
  11. Sahil_lihas
    Honeycomb May 27, 2020
    Sahil_lihas , via OnePlus 7 Mirror Blue , May 27, 2020 :
    what is the problem u all r facing ?
  12. Imrankhan6055
    I face the same issue. It shows only charging instead of warp charging. It charges the phone very slow.
  13. Sahil_lihas
    Imrankhan6055
    I face the same issue. It shows only charging instead of warp charging. It charges the phone very slow.​
    Oneplus 7 and 7 pro only support Dash Charge not warp charging, if you don't believe you can search in the forum itself.
  14. Imrankhan6055
  15. Imrankhan6055
  16. Sahil_lihas
  17. sarahmic
    sarahmic , May 27, 2020 :
    OP7 Pro has Warp charging and i've been using it for about 8/10 months.
    It always showed the Warp symbol of charging when i connected to electricity.
    But after last update not any more !!!!
    That's the problem!
  18. Swejuggalo
    OnePlus 9 Series Expert Community Expert May 27, 2020
    Swejuggalo , via OnePlus 7 Pro , May 27, 2020 :
    Have you tried using the cable on a computer USB port and charged a few minutes and then back to using warp charger? If that fixes it it is some kind of software bug. If it does not and you haven't been trying a other warp charger and cable try it. If it works then it was the cable or charger. If not then either it's probably the charge port. Either some debri or damaged somehow
  19. sarahmic
    So from a Computer Port the red cable charges the phone and i can see the number going slowly up.
    Then i switched off completely the OP7 Pro, and connected the warp charger and connected to electricity - started charging and it shows me a blue lightning symbol and it's charging fast in my opinion because from 53% Accubattery tells me that it will at 80% in 12 /13 mins.
    What am i to understand so please?
  20. Swejuggalo
    I read about some other users that got warp working by just slow charge the device a moment and then switch back to orginal charger.
    So you get warp but only when the phone is off?
    sarahmic likes this.
