251
OxygenOS 10.0.5 [EU and Global] and 10.3.2 [India] for the OnePlus 7 Pro and OnePlus 7
  1. Swejuggalo
    Lollipop Apr 4, 2020
    Swejuggalo , via OnePlus 7 Pro , Apr 4, 2020 :
    Already traces of it in current betas (but not available to users). My guess is that 8 series may have it at launch and the rest will get it later.
  2. Swejuggalo
    Sanjeev16895 likes this.
  3. Shiva_Rohith
    Gingerbread Apr 4, 2020
    Shiva_Rohith , via OnePlus 7 , Apr 4, 2020 :
    there'll be no problem right.? charging phone overnight?
  4. Chand6391
    Chand6391 , via OnePlus 7 Pro , Apr 4, 2020 :
    Good morning sir. Recently updated the software. After the update the following issues im from past few days.
    1. Camera getting stuck.
    2. Phone hangs
    3. Apps not responding properly
    4. Bluetooth connectivity issue
    Please kindly check the stats sir.
    * Camera quality is best with first OS of 7 pro than now sir.
    Thank you sir.
    Sunil+ likes this.
  5. Swejuggalo
    No. Infact Android will optimize at 100% and connected to charger if being connected enough time. Constantly disconnecting at 80% for example can cause a poorly optimized system. The end result will be more drain and in need of more charging, eating up all the saving of battery life you are trying to do.
    There are manual ways to start the optimize too. But you need to run a ADB command.
    Optimizing command. Run in adb shell if unrooted.
    cmd package bg-dexopt-job
    That and more battery info here.
    http://bit.ly/33bqDY2
    Direkt link.
    https://forums.oneplus.com/threads/...-and-battery-calibration-myths-busted.993896/
    X1565230218535 likes this.
  6. .blue.
    Cupcake Apr 4, 2020
  7. Swejuggalo
    EU firmware?
    Sometimes EU firmware comes later than International. It's normal. But I think it would have been better to rollout both at the same time to avoid confusion and annoyance.
    Also Oxygen Updater relies on real users actually reciving the OTA with the app installed and reporting the filename automatically from the app.
  8. Federico Prencipe
    Honeycomb Apr 4, 2020
    Federico Prencipe , Apr 4, 2020 :
    It's normal, you have to wait up to two weeks sometimes. I have a lot to blame on OP but not staged rollout, at least in the way they're meant to work and to be smart.
  9. Rkhanna96 , via OnePlus 7 Pro Mirror Gray , Apr 4, 2020 :
    I am facing heating issues and game crashing issues in middle of the game playing on my ineplus7 pro device.
    Most of the times screen goes blank and overheat while playing.
    what are issues here can anyone suggest.??
  10. Nurur
    Cupcake Apr 4, 2020
  11. Shiva_Rohith
    Thank you [e]1f60a[/e]
  12. akshay10dj
  13. Sagarshaikh
    Froyo Apr 4, 2020
  14. James Daniel Grant , via OnePlus 7 , Apr 4, 2020 :
    I can't update my OnePlus 7 with I have to have the full ROM do you have that
  15. Swejuggalo
  16. faizbodle
    Froyo Apr 4, 2020
    faizbodle , via OnePlus 7 , Apr 4, 2020 :
    Swejuggalo
    Direkt link.
    Are you suggesting that charging phone till 100% everytime will not cause any damage and is good for the phone?
  17. Ciprian Flower
    Ciprian Flower , Apr 4, 2020 :
    you should seek help for your problems, before it affects the people around you.
  18. Ciprian Flower
    just remove the bottom white bar from settings, you.re welcome.
  19. Mohanoctane8 likes this.
