251
OxygenOS 10.0.5 [EU and Global] and 10.3.2 [India] for the OnePlus 7 Pro and OnePlus 7
  1. MelvinAbes
    Gingerbread Apr 4, 2020
    MelvinAbes , Apr 4, 2020 :
    And for what reason?
    X1568888095586 likes this.
  2. Sagarshaikh
    Froyo Apr 4, 2020
    MelvinAbes and X1568888095586 like this.
  3. Rushrav
    Donut Apr 4, 2020
  4. MelvinAbes
    Three points :
    1)All of Oneplus's stable updates will be a staged rollout meaning it will be pushed to limited devices in the beginning before being pushed to all eligible devices. Always has and always will be this way.
    2)There is no ground breaking bug prior to this update that would deem anybody "sufferable"
    3) This is a forum, Clouding it with unnecessary content only detoriates from the overall community experience.
    Kindly wait and the update will be rolled out to all devices.
    Thank You.
    Sagarshaikh likes this.
  5. Swejuggalo
    Lollipop Apr 4, 2020
    Swejuggalo , via OnePlus 7 Pro , Apr 4, 2020 :
    You don't need 100% every single time no. But avoiding it completely does more harm than good. Draining battery close to 0 does more harm than a full charge. Also extreme heat and cold will affect the battery.
    Long term storage needs 50%, maintenance charging, and a controlled temperature. Not very user friendly if you actually want to use the device. And Android itself wants 100% for some maintenance work.
    Even the time the phone stays on the shelf waiting for an owner the battery slowly degrades... Don't worry that much. The only true way to save a battery would be not to manufacture it to begin with 😋
    Optimized charging is being tested in beta channel. It will keep it at 80% during most of the night and finish charging to 100% in good time before you wake up. That way you both get optimizing done and you don't need to be at 100% during most of the night.
  6. Swejuggalo
    Lockbox? Tried joining beta for the File manager? What version now?
    How does it not work?
    4 digit pin unlock has been upgraded to 6 digits. That broke it for those that registered with 4 pin. Now fingerprint should work as standard and you can change to a new 6 digit pin after fingerprint unlock.
    That fix is at Filemanager 2.6.X
  7. O1562771107557
    Donut Apr 4, 2020
  8. zaveed
    Donut Apr 4, 2020
    zaveed , via OnePlus 7 , Apr 4, 2020 :
    Can some upload the OnePlus 7 Global and India (GM57AA) full zip file if they have it. Oxygen updater is not showing the update neither connecting to other countries through VPN is yielding any results.
    neither XDA not other resources have this file yet.
    Thanks
  9. F_Daniel_Pedro_fJYF
    Eclair Apr 4, 2020
  10. Rushrav
    Donut Apr 4, 2020
    Rushrav , via OnePlus 7 , Apr 4, 2020 :
    Swejuggalo
    That fix is at Filemanager 2.6.X​
    file manager app version is as attached and I haven't joined beta for any app which are installed on my phone
  11. Rushrav
    Donut Apr 4, 2020
  12. Federico Prencipe
    Honeycomb Apr 4, 2020
    Federico Prencipe , Apr 4, 2020 :
    Charging the phone to 100% doesn't cause any damage to the battery, it just wear faster because electrons create more friction and then more heat and physical stress (it's a much more complex thing to explain) so charging between 20% and 80% is the healtier choice for the battery.
    The Oxygen OS unluckily optimize itself only when the phone is fully charged and taken pluggen in for some time, and there is a logic beneath this procedure.
    sarahmic and faizbodle like this.
  13. bagufix
  14. Swejuggalo
    There is a known issue since they updated from 2.4.x to 2.5.x.
    2.6.x is comming and should restore functions for everyone that register and started using it at 2.4.x.
    If you are in a hurry and want 2.6.x join beta temporary. When upgrading to 2.6.x just leave and you get stable updates after that. Or fetch it from apkmirror
  15. Tumio
    Tumio , via OnePlus 7 Pro , Apr 4, 2020 :
    i have root and twrp .. can i use the same command?
  16. X1568888095586
    X1568888095586 , via OnePlus 7 Pro , Apr 4, 2020 :
    funny how funny
  17. SandeshChinchapur
    Ice Cream Sandwich Apr 4, 2020
    SandeshChinchapur , via OnePlus 7 , Apr 4, 2020 :
    I had this issue, and they've fixed it temporarily. If u want, I can share you that apk. Else wait for the beta update on play store.
  18. X1568888095586
  19. sarahmic
    sarahmic , Apr 4, 2020 :
    I agree that the right way is to charge between 20 - 80 but once in a while it's good to give the phone a full charge.
